Home » Archived » BIRT » Issue with using the IN clause and parameters
Issue with using the IN clause and parameters [message #156973] Thu, 27 April 2006 19:04
Originally posted by: alfiewong.gmail.com
Select * from runs where id in ( ? )
where ? is set to "20, 35" without the quotes and id is a number data type.
We are trying to run this query in our report but it only returns the
last value "35". We have tried changing the data types but nothing seems
to return both rows in the run table. Furthermore we have only tried
this in the preview mode.
Thank you,
Alfred Wong
Previous Topic:the last column's values do not show up,the first column's values are replaced by 0, 1, 3, 4 .. is i
Next Topic:Messge for a blank report
Current Time: Mon Jul 21 21:08:13 EDT 2025
Powered by FUDForum. Page generated in 0.07207 seconds
