Standalone GEF !!! [message #156936] |
Fri, 05 November 2004 01:21  |
Can somebody tell what it takes to make GEF work as
a standalone application. From my initial codewalk I
figured that the IEditorSite is the interface which binds
the editor with the Eclipse workbench.
Saw the GEF FAQ on this subject, but was not of
much help.
dhiraj
Re: Standalone GEF !!! [message #158034 is a reply to message #156936] |
Sun, 14 November 2004 21:51   |
We've never tried it, so can't really comment on this. But be prepared, for
it's not going to be easy. GEF's GraphicalEditor hierarchy is a good place
to start looking for dependencies. But there's no entrance point: GEF is
dependent on several things from platform (the Palette View, some actions,
externalized strings, etc.). You'll just have to try it out and see.
Isolate the GEF code, remove all the GEF features you don't need, and look
at the compile errors. You can search this newsgroup for previous
discussions on this subject.
"dhiraj" <dhiraj@gmail.com> wrote in message
news:cmf65h$93t$1@eclipse.org...
> much help.
> dhiraj
Re: Standalone GEF !!! [message #158061 is a reply to message #156936] |
Mon, 15 November 2004 08:03   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Standalone from what exactly?
dhiraj wrote:
> much help.
> dhiraj
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Standalone GEF !!! [message #158536 is a reply to message #156936] |
Thu, 18 November 2004 15:27  |
Originally posted by: none.nowhere.com
dhiraj wrote:
> much help.
> dhiraj
I have done this in a pretty hacky way. Simply implement a new version of
org.eclipse.core.runtime.Platform:
package org.eclipse.core.runtime;
import org.osgi.framework.Bundle;
public class Platform {
public static Bundle getBundle(String id) {
return null;
public static String getResourceString(Bundle bundle, String key) {
return null;
Then add all the jars:
draw2d, swt, jface, gef, runtime, ui, editors, workbench, osgi, views.
Make sure the above class is loaded before runtime.jar (ie. by setting it
before runtime.jar in the classpath).
Works for me on eclipse 3.1 with gef 3.0.1. Note I have only done this
using the ScrollingGraphicalViewer as a base, ie. not implemented as part
of an editor.
Peter
FUDForum. Page generated in 0.26880 seconds
