Home » Language IDEs » ServerTools (WTP) » Double invocation of contexts
Double invocation of contexts [message #156931] |
Tue, 17 January 2006 10:38  |
Originally posted by: caclark.etechsolutions.net
I've clean installed Eclipse 3.1.1 and WTP 1.0.1 maintenance release.
It migrated a couple of Web projects I have. When I add the projects to
a Tomcat 5.5 server definition and start it, the contexts are invoked
twice each. One of the apps fires up the Dumbster fake email server and
the other starts several threads to handle requests. Both have logging
turned on so I see both start twice.
Has anyone else seen this behavior? If so, what'd you do to cure it? I
have several other apps that I'd like to add to the server that run in
other contexts, so the doubled work load is not a good thing.
Cary
Re: Double invocation of contexts [message #156955 is a reply to message #156931] |
Tue, 17 January 2006 12:22   |
Starting with WTP 1.0, projects are published to Tomcat's CATALINA_BASE
"webapps" directory. With the default configuration of Tomcat, this
guarantees you will get one context served using the apps directory
name. At the moment, the Tomcat support uses the project name to
publish the app, so if you specified a different context-root in your
project, then the resulting <Context> element added to server.xml will
invoke another context using the context-root. For now, the simplest
way to avoid this is to keep the project name and the context-root the
same. If this approach can't be used, you can turn off auto-serving by
setting in the server.xml:
<Host deployOnStartup="false" autoDeploy="false" ...>
This will disable auto-serving of the "default" ROOT webapp. Adding the
following context to server.xml should bring it back:
<Context docBase="ROOT" path="" reloadable="false"/>
Reloading shouldn't be needed since it doesn't change.
HTH,
Larry
Cary wrote:
> I've clean installed Eclipse 3.1.1 and WTP 1.0.1 maintenance release. It
> migrated a couple of Web projects I have. When I add the projects to a
> Cary
Re: Double invocation of contexts [message #157000 is a reply to message #156955] |
Tue, 17 January 2006 14:35   |
Yep, that was it. I have my projects named with long, readable names
but the context roots are short. I set the 2 attributes on the <Host>
that you suggested and things are good.
While the topic is current, what prevents the Tomcat server def from
using the context root specified in .components? I know there's always
the special case of having an empty one. Are there others?
BTW, am I the only one that runs apps frequently without a context root?
The Glassfish and Geronimo plugins have real difficulty with that.
Thanks for the pointers,
Cary
Larry Isaacs said the following on 1/17/2006 11:22 AM:
> HTH,
> Larry
>> to a Tomcat 5.5 server definition and start it, the contexts are
>> invoked twice each. One of the apps fires up the Dumbster fake email
>> server and the other starts several threads to handle requests. Both
>> have logging turned on so I see both start twice.
>> I have several other apps that I'd like to add to the server that run
>> in other contexts, so the doubled work load is not a good thing.
>> Thanks,
>> Cary
Re: Double invocation of contexts [message #157023 is a reply to message #157000] |
Tue, 17 January 2006 16:23   |
This behavior is a side effect of the ".deployables" directory (from WTP
0.7) going away, and which hasn't been properly addressed yet in WTP
1.0. It's on my to-do list to check for an existing bug and enter one
if there isn't one already. Also on the to-do list is to think about
how it should be addressed. There may be enough reasons that webapps
shouldn't be published to the "webapps" directory.
As for your question, WTP should be using the context-root from
..components. In 0.7x, specifying "" as was supported. That webapp
would take precedence and "replace" the ROOT webapp that is there by
default. Regrettably, I haven't had time to test if this still works in
WTP 1.0.
Larry
> Cary
>> CATALINA_BASE "webapps" directory. With the default configuration of
>> Tomcat, this guarantees you will get one context served using the apps
>> directory name. At the moment, the Tomcat support uses the project
>> name to publish the app, so if you specified a different context-root
>> in your project, then the resulting <Context> element added to
>> server.xml will invoke another context using the context-root. For
>> now, the simplest way to avoid this is to keep the project name and
>> the context-root the same. If this approach can't be used, you can
>> turn off auto-serving by setting in the server.xml:
>> the following context to server.xml should bring it back:
>> HTH,
>> Larry
>>> it? I have several other apps that I'd like to add to the server
>>> that run in other contexts, so the doubled work load is not a good
>>> thing.
>>> Thanks,
>>> Cary
Re: Double invocation of contexts [message #157031 is a reply to message #157023] |
Tue, 17 January 2006 17:01   |
I have several web apps deployed into this Tomcat server now. I have
the latest maintenance drop of the code, so there is the J2EE property
page for the projects. I have one that has nothing in there. Its
..component has this line:
<property name="context-root" />
which you would expect. In the server.xml, the context has this path
attribute: path=""
It does, in fact, replace the default ROOT web app; I've been running
some real world tests on it. So, that part is working in 1.0.x....
BTW, the latest maintenance drop has done wonders for performance. I
recommend everyone that was have performance issues with 1.0 update
immediately.
Thanks for your help.
Cary
Larry Isaacs said the following on 1/17/2006 3:23 PM:
> WTP 1.0.
> Cheers,
> Larry
>> always the special case of having an empty one. Are there others?
>> root? The Glassfish and Geronimo plugins have real difficulty with
>> that.
>> Cary
>>> apps directory name. At the moment, the Tomcat support uses the
>>> project name to publish the app, so if you specified a different
>>> context-root in your project, then the resulting <Context> element
>>> added to server.xml will invoke another context using the
>>> context-root. For now, the simplest way to avoid this is to keep the
>>> project name and the context-root the same. If this approach can't
>>> be used, you can turn off auto-serving by setting in the server.xml:
>>> HTH,
>>> Larry
>>>> release. It migrated a couple of Web projects I have. When I add
>>>> the projects to a Tomcat 5.5 server definition and start it, the
>>>> contexts are invoked twice each. One of the apps fires up the
>>>> Dumbster fake email server and the other starts several threads to
>>>> handle requests. Both have logging turned on so I see both start
>>>> twice.
>>>> thing.
>>>> Thanks,
>>>> Cary
Re: Double invocation of contexts [message #157157 is a reply to message #157031] |
Wed, 18 January 2006 12:08  |
Cary said the following on 1/17/2006 4:01 PM:
> attribute: path=""
> immediately.
> Cary
>> WTP 0.7) going away, and which hasn't been properly addressed yet in
>> WTP 1.0. It's on my to-do list to check for an existing bug and enter
>> one if there isn't one already. Also on the to-do list is to think
>> about how it should be addressed. There may be enough reasons that
>> webapps shouldn't be published to the "webapps" directory.
>> in WTP 1.0.
>> Cheers,
>> Larry
>>> <Host> that you suggested and things are good.
>>> that.
>>> Cary
>>>> of Tomcat, this guarantees you will get one context served using the
>>>> the project name and the context-root the same. If this approach
>>>> can't be used, you can turn off auto-serving by setting in the
>>>> server.xml:
>>>> HTH,
>>>> Larry
>>>>> twice.
>>>>> thing.
>>>>> Thanks,
>>>>> Cary
Just a follow up on the context root. It must have worked be it was set
that way before the 1.0 install. If you type anything in the property
page's Context Root field, it will not let you set it empty. I'll look
to see if there's a bug open on this and open one if not.
Cary
Current Time: Mon Jul 21 21:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.15583 seconds
