Home » Modeling » TMF (Xtext) » Re: [TCS] Referencing
Re: [TCS] Referencing [message #14703] Thu, 29 May 2008 14:57 Go to next message
--------------080301000608030007040407
Hi Jose,
Please use the TMF newsgroup for TCS questions. I've added it to the
"to" list of the reply.
Freddy.
Jose E. Rivera a
Re: [TCS] Referencing [message #14733 is a reply to message #14703] Fri, 30 May 2008 05:05 Go to previous messageGo to next message
Hi Jose,
I am not sure to understand what you mean. Could you please give a code
example following your TCS specification the way you would like it to work?
Frédéric Jouault
Freddy Allilaire a écrit :
> Hi Jose,
> Freddy.
> Jose E. Rivera a écrit :
>> Hi all,
>> I'm using TCS and I need to serialize elements with complex
>> references. Not to complicate it more with my metamodel, I would
>> introduce what I want to do with the KM3 metamodel example.
>> Suppose that when serializing a KM3 reference, I would like to print
>> all the names of its containing class supertypes. I would like to do
>> something like that(last line):
>> template Reference addToContext:
>> "reference" name $multiplicity (isContainer? "container")
>> ":" type{refersTo= name, autoCreate= never}
>> (isDefined(opposite) ? "oppositeOf" opposite{refersTo= name, lookIn=
>> type, autoCreate= never})
>> owner.superTypes{refersTo = name, separator = ","} ";";
>> But TCS does not allow me (i can not use the dot (owner.superTypes) as
>> I expected). Is there any way to handle it?
>> Thanks in advance,
>> Jose E. Rivera
Re: [TCS] Referencing [message #14763 is a reply to message #14733] Mon, 02 June 2008 07:19 Go to previous messageGo to next message
Originally posted by: rivera.lcc.uma.es
For example, given the KM3 metamodel as well (class "Reference"), I
would like to produce something like:
class Reference extends StructuralFeature {
attribute isContainer : Boolean;
reference opposite[0-1] : Reference StructuralFeature;
Note "StructuralFeature" printed at the end of the reference "opposite".
I would need to access from a "Reference" to the supertypes of its owner...
I would like to write in TCS something like:
owner.supertypes{refersTo = name, separator = ","} ";";
(In the example there is only one supertype) Is there any way to do it?
Yhank you very much,
Jose
Frédéric Jouault escribió:
> Hi Jose,
> Frédéric Jouault
>> Hi Jose,
>> Freddy.
>>> Hi all,
>>> lookIn= type, autoCreate= never})
>>> as I expected). Is there any way to handle it?
>>> Thanks in advance,
>>> Jose E. Rivera
Re: [TCS] Referencing [message #14853 is a reply to message #14763] Fri, 13 June 2008 10:45 Go to previous messageGo to next message
since I have got no answer, can I assume that TCS does not allow to do
these kind of things?
Jose E. Rivera
Jose E. Rivera escribió:
> Jose
>> Hi Jose,
>> code example following your TCS specification the way you would like
>> it to work?
>> Thanks,
>> Frédéric Jouault
>>> Hi Jose,
>>> Freddy.
>>>> Hi all,
>>>> Thanks in advance,
>>>> Jose E. Rivera
Re: [TCS] Referencing [message #16481 is a reply to message #14763] Wed, 09 July 2008 10:39 Go to previous message
When you put StructuralFeature after Reference you are duplicating
information that is already in the definition of Reference.
What would you want to happen: 1) redefinition of the supertypes of
Reference, or 2) comparison of both definitions that generates an error
if they are inconsistent?
I must admit that I do not understand the point of your example. An
actual example may help me to understand what you want to do.
In any case, a simple work-around is to parse with a slightly modified
metamodel (with the corresponding structure), then use model
transformation to get to your actual metamodel.
Frédéric Jouault
> Jose
>> Hi Jose,
>> it to work?
>> Thanks,
>> Frédéric Jouault
>>> Hi Jose,
>>> Freddy.
>>>> Hi all,
>>>> Thanks in advance,
>>>> Jose E. Rivera
Previous Topic:fighting vertical silos
Next Topic:SPL sample context for LocalFunctionDeclarations
Current Time: Fri Nov 07 05:17:44 EST 2025
Powered by FUDForum. Page generated in 0.05515 seconds
