Home » Language IDEs » C / C++ IDE (CDT) » CDT with different Compilers
CDT with different Compilers [message #156872] Thu, 27 October 2005 09:18 Go to next message
Originally posted by: jan.potthast.name
I would like to use CDT with different compilers. I have seen in eclipse
under Project -> C/C++Build the possibility to generate various
configurations. But the configuration switches define only GNU Compiler
switches. Is there a possibility to use this grafical menu for other
compilers like Visual compiler or Borland compiler?
Greetings
Jan
Re: CDT with different Compilers [message #156901 is a reply to message #156872] Thu, 27 October 2005 19:02 Go to previous messageGo to next message
Originally posted by: eclipse.dharty.com
I'm not sure what you mean by
but I've been able to set up the project make options to use several
Project->Properties->C/C++ Make Project->Make Builder Tab.
Typically this involves a "hack" to first tell the system not to use the
default build command "make" and instead use your compiler or build
tool. EG. gbuild.exe is a tool Green Hills uses to build their
proprietary projects so I change the build command from make to
gbuild.exe HELMSMAN.gpj
where Helmsman.gpj is the project file. Then you can pass different
switches into the Build, Rebuild and Clean builds depending on your
compiler.
You can also use Make targets to do the same thing, with a bit of extra
extendability:
Here is a sample make target that builds a given project in a given
solution..
Target Name:
VSProject
Make Target:
FlightSoftware.sln /build debug /project FlightSim.vcproj
Build Command:
c:\Program Files\Microsoft Visual Studio .NET 2003\Common7\IDE\devenv.com
Here is a sample using the gbuild command
Target Name:
HELMSMAN-All
Make Target:
HELMSMAN.gpj
Build Command:
gbuild.exe -all
Of course in this case, gbuild is on my path.
HTH
David
Jan wrote:
> Hello,
> Greetings
> Jan
Re: CDT with different Compilers [message #156992 is a reply to message #156872] Fri, 28 October 2005 19:03 Go to previous messageGo to next message
Originally posted by: bjcbell.gmail.com
Jan wrote:
> Hello,
> Greetings
> Jan
Jan,
If you are using Standard Build, just write a makefile to use whatever
tool you want. If you are using managed build, you can write a plug in
to work with your tool, Check out
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/cdt-home /user/Reference%20Documents/Managed_Build_21/Managed_Build_E xtensibility.html?cvsroot=Tools_Project
(Sorry for the long URL). It has instructions on how to create your own
plug in.
Re: CDT with different Compilers [message #157161 is a reply to message #156872] Mon, 31 October 2005 16:53 Go to previous messageGo to next message
I have a similar problem and have been experimenting with an
Ant plugin called cc http://ant-contrib.sourceforge.net/cc.html.
It has a lot of promise. It would be nice though, if the
"Managed Make" option that we have, would actually create
Ant build files instead of make files. This would benefit
both the C++ developers and the Java developers.
Mark Fortner
Jan wrote:
> Hello,
> Greetings
> Jan
Re: CDT with different Compilers [message #639566 is a reply to message #156901] Tue, 16 November 2010 17:33 Go to previous message
I have my default.gpj project in Multi from Green Hills and I would like to know how I can integrate this project in eclipse. I'm using eclipse Helios and I've imported my Green Hills libraries to eclipse. I can make a green Hills project from eclipse and I add my BSP version and other features but when I build the project, there are errors and i don't know why? Someone can help me?
oscar.
Previous Topic:Parsing Green Hills Build output in Eclipse
Next Topic:Debugging Matlab mex files (c/c++) within Eclipse
Current Time: Fri Jul 18 03:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.28291 seconds
