Home » Eclipse Projects » Eclipse Platform » Dumb Plugins and Instances ...
Dumb Plugins and Instances ... [message #156822] Fri, 14 November 2003 09:32
I created a dumb plugin called Host just like an example using IListener and
callbacks. I have an Editor plugin action that I used the
Platform.getPlugin method to obtain the Host and then the action run()
method would call the proxy method on the Host plugin. When debugged, the
Host is null. Am I supposed to write code to instance the dumb plugin since
it has no GUI? The dumb plugin does have a constructor like ...
public Host(IPluginDescriptor descriptor) {
super(descriptor);
instance(this);
Why does the Editor's action run() method return NULL when the menu action
is called?
Here's the run method(IAction action) {
Host host = (Host) Platform.getPlugin(HOST_PLUGIN);
host.update("Hello there");
David
David L. Whitehurst
aka. PiratePete
http://www.piratepetesoftware.com
dlwhitehurst@comcast.net
Previous Topic:Weird error while copying CompilationUnitEditor(Cont)
Next Topic:integrating a debugger
Current Time: Mon Jul 21 21:31:35 EDT 2025
Powered by FUDForum. Page generated in 0.27072 seconds
