Home » Language IDEs » C / C++ IDE (CDT) » Favorite documentation system for C++
Favorite documentation system for C++ [message #156812] Wed, 26 October 2005 10:16 Go to next message
Originally posted by: siegfried.heintze.com
I see there is an ajdoc feature in eclipse. Is this for java programmers
only? I think so. Is there a counterpart to javadoc that is built into
eclipse -- doxygen perhaps? I could not find one.
Siegfried
Re: Favorite documentation system for C++ [message #156819 is a reply to message #156812] Wed, 26 October 2005 10:26 Go to previous messageGo to next message
as far as I know there is no built-in functionality. You'll have to
include doxygen yourself,
probably in your makefile as a separate target.
If you use the managed project, you'll have to figure out yourself, I
never used it.
andrés
Am Wed, 26 Oct 2005 16:16:14 +0200 schrieb siegfried heintze
<siegfried@heintze.com>:
> Siegfried
Written with Opera
Re: Favorite documentation system for C++ [message #156827 is a reply to message #156812] Wed, 26 October 2005 11:05 Go to previous messageGo to next message
Originally posted by: berend.chalmers.se
There is an excellent plugin for doxygen in eclipse,
http://home.gna.org/eclox/
Berend.
Re: Favorite documentation system for C++ [message #156834 is a reply to message #156827] Wed, 26 October 2005 11:57 Go to previous messageGo to next message
This is a question on the doxygen/eclipse plugin:
I was hoping there would be a URL that I could just point eclipse to.
Instead there is a zip file I downloaded. What do I do with this zip file?
Do I extract it to my plugin directory in eclipse?
Siegfried
Re: Favorite documentation system for C++ [message #156840 is a reply to message #156834] Wed, 26 October 2005 14:05 Go to previous messageGo to next message
> file? Do I extract it to my plugin directory in eclipse?
> Siegfried
Open the eclox-0.3.4.bin.zip file and read the manual.file.
1. INSTALLATION
To install this plugin, follow the common installation procedure
consisting
in copying the whole plugin folder into Eclipse's plugin folder. For
additional details, please refer to Eclipse's documentation.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Favorite documentation system for C++ [message #158472 is a reply to message #156840] Fri, 18 November 2005 17:57 Go to previous message
Originally posted by: m.fortner.sbcglobal.net
One other approach is to use the doxygen package in the Cygwin setup
program. Once you have it, then you need to configure an External Tool
(it's the icon next to the Run button that has a suitcase on it).
Right click on the down arrow next to the "Run External Tool" icon and
select the "External Tools..." menu item.
When the dialog box appears, click on the "Program" node in the tree on
the left, and click the "New" button to add a new configuration.
In the form on the right hand side, make the following entries in the fields
Working Directory: ${project_loc}
You'll also want to make sure that the "dot" graphics program from
GraphViz (http://www.graphviz.org/) is in your path since this will
generate the class diagrams for you.
Hope this helps,
Mark
>> Thanks,
>> Siegfried
> 1. INSTALLATION
> consisting
Previous Topic:configuring remote debug from windows to linux
Next Topic:sporadic indexer behavior/non-behavior
Current Time: Thu Nov 06 12:05:09 EST 2025
Powered by FUDForum. Page generated in 0.04107 seconds
