Home » Language IDEs » Java Development Tools (JDT) » MyEclipse plug-in: how to import a sample application
MyEclipse plug-in: how to import a sample application [message #156809] Fri, 30 April 2004 12:04 Go to next message
Originally posted by: ChuckChopp.rtfmcsi.com
I'm using Eclipse v2.1.3 with the MyEclipse plug-in.
I have unpacked a .jar file that contains a sample Struts web application.
this sample app was obtained from the companion web site for the book "The
Struts Framework". This is the "cdmanagersample" app from the www.mkp.com
web site.
I'm trying to figure out how to import this sample application into a
project using the MyEclipse plug-in. I used MyEclipse to create a new J2EE
Web Module Project, and it appears that the layout of the subdirectories and
the subdirectory names is a little bit different between the the new project
and the sample application.
What is the proper method for importing an existing application that doesn't
have any of the MyEclipse-related projtect metadata attached to it already?
TIA,
Chuck
Re: MyEclipse plug-in: how to import a sample application [message #156820 is a reply to message #156809] Fri, 30 April 2004 12:57 Go to previous message
Hmmm... never mind, I think I figured it out. "File -> Import" allows me to
import files into my project. I now need to resolve some errors about some
tags that cannot be loaded by a bunch of JSPs; it looks like one tag library
cannot be located for some reason.
Previous Topic:comment block style
Next Topic:is there a way to use ordinary cursor and smart indent at the same time?
Current Time: Sat Jun 07 13:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.03628 seconds
