Home » Archived » BIRT » Total.sum is not working
Total.sum is not working [message #156716] Thu, 27 April 2006 06:49 Go to next message
Originally posted by: a.samoylov.bashtel.ru
I use birt 2.1RC0 and Oracle. If i add to my report a expression
Total.sum(row["WCNT"]) in the viewer showing a error
org.mozilla.javascript.EcmaError: ReferenceError: "Total" is not defined.
(<inline>#1)
How to prevent this error?
Re: Total.sum is not working [message #156807 is a reply to message #156716] Thu, 27 April 2006 11:29 Go to previous messageGo to next message
I just tried this with the sample db (attached) and it worked. What is the
datatype for WCNT?
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.1"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.0.N20060415-1243 Build &lt;20060415-1243></property>
<property name="units">in</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source" id="4">
<text-property name="displayName">Data Source</text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<text-property name="displayName">Data Set</text-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<property name="queryText">select *
from orderdetails</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">Total.sum(dataSetRow["QUANTITYORDERED"]) </expression>
</structure>
<structure>
<expression name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="35"/>
<column id="36"/>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<header>
<row id="7">
<cell id="8">
<label id="9">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="10">
<label id="11">
<text-property name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="12">
<label id="13">
<text-property name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="18">
<cell id="19">
<data id="20">
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="21">
<data id="22">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="23">
<data id="24">
<property name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="29">
<cell id="30"/>
<cell id="31"/>
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
</row>
</footer>
</table>
</body>
</report>
"Andrey Samoylov" <a.samoylov@bashtel.ru> wrote in message
news:cdb212e166c2cc44a2625ce05665f9b0$1@www.eclipse.org...
> (<inline>#1)
Re: Total.sum is not working [message #156845 is a reply to message #156807] Thu, 27 April 2006 13:10 Go to previous messageGo to next message
Originally posted by: vladperl.semanticprogrammer.org
Hi Jason,
I have the same problem. I'm using birt 2.1 RC1.
See below:
Error0 : Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "totalVisits = Total.sum(row["VisitCount"]);".
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:520)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:482)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJSInternal(ScriptExecutor.java:67)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJS(ScriptExecutor.java:51)
org.eclipse.birt.report.engine.script.internal.DataItemScrip tExecutor.handleOnCreate(DataItemScriptExecutor.java:52)
org.eclipse.birt.report.engine.executor.DataItemExecutor.exe cute(DataItemExecutor.java:94)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitDataItem(ReportExecutorVisitor.java:158)
org.eclipse.birt.report.engine.ir.DataItemDesign.accept(Data ItemDesign.java:69)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ac cessRow(TableItemExecutor.java:606)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ac cessTableBand(TableItemExecutor.java:502)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ac cessHeader(TableItemExecutor.java:351)
org.eclipse.birt.report.engine.executor.ListingElementExecut or.accessQuery(ListingElementExecutor.java:116)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:151)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:188)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
org.eclipse.birt.report.engine.executor.GridItemExecutor.exe cuteCell(GridItemExecutor.java:261)
org.eclipse.birt.report.engine.executor.GridItemExecutor.exe cuteRow(GridItemExecutor.java:196)
org.eclipse.birt.report.engine.executor.GridItemExecutor.exe cute(GridItemExecutor.java:124)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitGridItem(ReportExecutorVisitor.java:173)
org.eclipse.birt.report.engine.ir.GridItemDesign.accept(Grid ItemDesign.java:117)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:171)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.BaseFragmen t.service(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Unknown Source)
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "Total" is not
defined. (<inline>#1)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3303)
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1632)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1571)
at org.mozilla.javascript.gen.c98._c0(<inline>:1)
at org.mozilla.javascript.gen.c98.call(<inline>)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c98.exec(<inline>)
at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:513)
... 60 more
Re: Total.sum is not working [message #156853 is a reply to message #156845] Thu, 27 April 2006 13:15 Go to previous messageGo to next message
Vladimir,
Can you try the report I attached to my last post?
Jason
"Vladimir" <vladperl@semanticprogrammer.org> wrote in message
news:e2qtt7$5cl$1@utils.eclipse.org...
> Hi Jason,
> See below:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> not defined. (<inline>#1)
> at
> at
> at
> at
> at
> at
> ... 60 more
Re: Total.sum is not working [message #156891 is a reply to message #156853] Thu, 27 April 2006 14:01 Go to previous messageGo to next message
For some reason your report is working with total.
I have found related to this problem the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136506
Could you provide some additional explanations on the issue?
Looks like this bug has fixed only yesterday.
Thank you,
Vladimir
Re: Total.sum is not working [message #156899 is a reply to message #156891] Thu, 27 April 2006 14:19 Go to previous messageGo to next message
That was using Total in the group header or TOC for example.
The example I posted used it on a data element in a detail.
I would imagine the fix will be in RC2.
Jason
news:e2r0sv$e4m$1@utils.eclipse.org...
> Thank you,
> Vladimir
Re: Total.sum is not working [message #156907 is a reply to message #156899] Thu, 27 April 2006 16:19 Go to previous message
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e2r1vi$hh7$1@utils.eclipse.org...
Thank you for the explanation.
In many cases I'm using Total in the group header so I see now why I'm
getting this error.
I will wait for RC2.
Thanks again.
Vladimir
Previous Topic:Cross tabulation
Next Topic:Report generation problem
Current Time: Mon Jul 21 21:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.28768 seconds
