Home » Modeling » GMF (Graphical Modeling Framework) » elements dragged out of border
elements dragged out of border [message #156679] Mon, 22 October 2007 11:31 Go to next message
Originally posted by: exquis.nospam.com
Hi All,
I am facing this problem where when I drag an item out of the boundary of
parent container, the item as well as its connections with other child
items becomes invisible. Two small arrows comes in the corner to show that
you can scroll but its kind of confusing as I am not sure how many people
will see those small arrows in the corner. I am looking for a solution
where when I drag the child item out of the parent boundary and parent
border should also stretch and allow child item to visible inside it,
istead of getting disappeared. What should be the approach for this.
Re: elements dragged out of border [message #156710 is a reply to message #156679] Mon, 22 October 2007 13:22 Go to previous messageGo to next message
Let me explain more accurately. I want to stop user from resizing the
parent container if because of resizing any child element getting hidden.
I think that way the problem will be resolved. How can I enforce this.
Re: elements dragged out of border [message #157351 is a reply to message #156710] Fri, 26 October 2007 15:38 Go to previous message
Does the parent container resize itself to the size you want when you
press the Autosize button? If so, you could leave the parent container
in autosize mode always (that is, the bounds constraint should have a
size of (-1,-1)) and remove the resizable editpolicy.
Cherie
> hidden. I think that way the problem will be resolved. How can I enforce
> this.
Previous Topic:How to create a simple schematic editor
Next Topic:Placement of Connector Label
Current Time: Sat May 10 15:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.03418 seconds
