Home » Language IDEs » C / C++ IDE (CDT) » Problem with debugger - "File /mydir/.settings does not exist".
Problem with debugger - "File /mydir/.settings does not exist". [message #156668] Sun, 23 October 2005 20:35 Go to next message
Originally posted by: pretzel_n_g.hotmail.com
I'm using CDT 3.0.0 and Cygwin/gcc/g++ or WinXP.
When I try to debug my c++ application, the debugger stops at the
appropriate lines where breakpoints have been set (as indicated in the
"Debug" tab - says "Thread[1] (Suspended) |->1 main() at
...\blahblah.cpp:24" etc. etc.) however, it doesn't point to which line
in the source code listing.
In fact when I fire up the debugger I get a panel which says the following:
This panel also comes up whenever I right-click the "Debug" panel and
select "Lookup source".
When I examine the directory structure of the project, a directory
called ".settings" exists but no file.
Would anyone please be able to help me to get the debugger working
properly please?
Thanks very much for your help.
PretzelX.
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #156696 is a reply to message #156668] Mon, 24 October 2005 10:30 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
This bug has been fixed in the Eclipse 3.1 M6. Which version of Eclipse are
you using?
"PretzelX" <pretzel_n_g@hotmail.com> wrote in message
news:djha9f$kri$1@news.eclipse.org...
> ..\blahblah.cpp:24" etc. etc.) however, it doesn't point to which line in
> following:
> When I examine the directory structure of the project, a directory called
> properly please?
> PretzelX.
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #156768 is a reply to message #156696] Tue, 25 October 2005 19:44 Go to previous messageGo to next message
I'm using Eclipse 3.1.0. Thanks for that hint - I will download the
latest Eclipse.
I appreciate your help!
PretzelX.
> you using?
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #156848 is a reply to message #156768] Wed, 26 October 2005 17:30 Go to previous messageGo to next message
Eclipse 3.1 M6 is the milestone 6 of the Eclipse 3.1.0 version. This bug
should be fixed in the version you are using.
news:djmg11$m1v$1@news.eclipse.org...
> latest Eclipse.
> PretzelX.
>> are you using?
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #167673 is a reply to message #156668] Sat, 08 April 2006 14:46 Go to previous messageGo to next message
Originally posted by: shea08.eastlink.ca
I am seeing the same problem. I build the debug version with -g3. Then
hit debug. I believe the program stop at my break point, but the editor
shows not indication of where it stopped. Also, stepping into a funtion
does not update the editor. The output on the console tab is this:
<output>
No registers.
No source file named main.cpp.
Stopped due to shared library event
Single stepping until exit from function main,
which has no line number information.
Single stepping until exit from function __libc_start_main,
</output>
I am using eclipse 3.1.2, with latest cdt. gcc4.0.3, and gdb 6.4.
Thanks.
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #167681 is a reply to message #167673] Sat, 08 April 2006 14:54 Go to previous message
> <output>
> No registers.
> </output>
> Thanks.
I figured it out. Just run Debug... and make sure it is pointing out
the Debug binary, not the release. Stupid me...
~S
Previous Topic:Outline
Next Topic:C in WinXP
Current Time: Sat Jul 12 20:01:20 EDT 2025
Powered by FUDForum. Page generated in 0.05472 seconds
