Home » Language IDEs » C / C++ IDE (CDT) » svn: Debug and Release under versioncontrol
svn: Debug and Release under versioncontrol [message #156658] Sat, 22 October 2005 15:39 Go to next message
Originally posted by: v.thoma.htp-tel.de
Hi everyone,
I want the configurstion data from release and debug store under
versioncontrol by subversion.
I use Eclipse 3.1.1 under Linux, subclipse 0.9.34 (java-client) and the
subversion server 1.23.
Any idea ?
best regards
Re: svn: Debug and Release under versioncontrol [message #157112 is a reply to message #156658] Mon, 31 October 2005 13:39 Go to previous messageGo to next message
I have no idea, what the heck you really mean.
I do a guess:
* Do you want CDT from source?
CDT is stored under CVS not subversion (see CDT website)
* Do you want to store a configuration of your project (compiler/linker
settings) stored in subversion?
Include the .cdtproject, .project (hidden by Project Explorer) file
in your subversion.
Include the compile folders (Release and Debug) to subversion.
Next time, make a clear question.
Volker Thoma schrieb:
> Hi everyone,
> Any idea ?
> best regards
Re: svn: Debug and Release under versioncontrol [message #158899 is a reply to message #157112] Thu, 24 November 2005 05:48 Go to previous messageGo to next message
This is what I want todo.
> in your subversion.
Where are the compile folders stored? They are not stored under
the project folder, is it possible to store them under the project folder?
Re: svn: Debug and Release under versioncontrol [message #158937 is a reply to message #158899] Thu, 24 November 2005 09:15 Go to previous messageGo to next message
Perhaps a stupid question, but why do you want your compile folder to be
stored into Subversion? These files should not be stored in a version
control system!
Re: svn: Debug and Release under versioncontrol [message #158951 is a reply to message #158937] Thu, 24 November 2005 09:37 Go to previous messageGo to next message
> control system!
I actually dont know which files I should put into version control.
The thing I want to accomplish is that when I check out a project
I dont have to manually setup project specific settings like,
Environment variable, Make definitions, GDB info etc.
But It doesnt seem to be possible in a simple way.
/T
Re: svn: Debug and Release under versioncontrol [message #158984 is a reply to message #158951] Fri, 25 November 2005 04:16 Go to previous messageGo to next message
Hi Toni,
you must distinguish between a project's build settings which describe
compiler, environment etc. for the build process and debug launch
configurations which describe the setup for debugging sessions.
The build configuration is stored it the project's base directory, in
..project, .cdtproject and (for managed make projects) .cdtbuild. They are
hidden in the C/C++ Projects View but visible in the Navigator view. Put
them under version control and you're done.
If you also want to share launch configurations, they are stored in the
metadata. I have not done this before, putting metadata under version
control is more tricky, since they also contain machine-specific and
user-specific settings so you do this at your own risk. The launch
configurations are stored as xml files in
<workspace>\.metadata\.plugins\org.eclipse.debug.core\.launches
Hope this helps
Norbert
"Toni Brkic" <tonib.brkic@switchcore.com> schrieb im Newsbeitrag
news:dm4j6g$4j4$1@news.eclipse.org...
>> control system!
> /T
Re: svn: Debug and Release under versioncontrol [message #159078 is a reply to message #158984] Sat, 26 November 2005 06:01 Go to previous messageGo to next message
Originally posted by: toni.brkic.switchcore.com
Norbert Ploett wrote:
> Hi Toni,
I tried this but you get problems if you put .project under version
control.
Since the .project contains the name of the workspace. Then I get
problems, since eclipse will get quite confused if I change the name of
my workspace name and checkin the changes.
Use Case with .project under version control:
I check out project/trunk into workspace trunk. Work there for
a while. Then I realize that i need to do a minor fix check
out project/trunk into workspace trunk2. Do my fix and checkin.
If developer two checks project/trunk into workspace trunk. He
will have trouble since .project hase the name setting to trunk2.
I really cant understand how you smoothly work with the combination
eclipse/subversion/cdt.
If .project didnt have the name attribute or you could put a relative
path there things would be much easier. I dont understand why it
is in there at all. Arent you supposed to have a one .project per
workspace.
Does somebody use the combination eclipse/subversion/cdt explain
how they set up things so that it works in a team.
> <workspace>.metadata.pluginsorg.eclipse.debug.core.launches
> Hope this helps
> Norbert
>>> control system!
>> /T
Re: svn: Debug and Release under versioncontrol [message #159148 is a reply to message #159078] Mon, 28 November 2005 02:26 Go to previous messageGo to next message
Hi Toni,
> control.
I cannot reproduce that .project contains the name of the workspace. Maybe
you can post a sample or figure out how it is that the workspace name is
there in your case. I am attaching a copy of a "workspace-less" .project.
Norbert
  • Attachment: .project
    (Size: 0.46KB, Downloaded 294 times)
Re: svn: Debug and Release under versioncontrol [message #159164 is a reply to message #159148] Mon, 28 November 2005 03:57 Go to previous messageGo to next message
> Hi Toni,
>> control.
> Cheers,
> Norbert
From your .project:
<projectDescription>
<name>test</name>
<comment></comment>
Where I guess that you named the workspace to test.
But maybe workspace name isnt the correct name but
it is this that gives the problems.
For example from mine I checked out trunk and renamed it I get:
<name>work_tonib</name>
If i check in this file other developers will get problems
when the check out.
Toni
Re: svn: Debug and Release under versioncontrol [message #159180 is a reply to message #159078] Mon, 28 November 2005 06:12 Go to previous messageGo to next message
I work on a WinXp pc, using CDT and TortoiseSVN.
The start of a new project (and, in most cases, a corresponding SVN
repoitory) is a little bit tricky.
I first set up the repository and the Eclipse project separately.
When I have created a project in Eclipse, I close it (so I'm sure it will
not update the project files any more), then I import the project into SVN
using TortoiseSVN (for a managed c/c++ project only the hidden
files/folder .project. cdtbuild .cdtproject .settings are taken along).
Only after that, I use the Subclipse plugin for SVN. By doing this I have
no conflicts or weird behaviour, and am able to share my project easily
with co-workers.
Does this help?
Re: svn: Debug and Release under versioncontrol [message #159187 is a reply to message #159180] Mon, 28 November 2005 08:59 Go to previous messageGo to next message
Hi Kurt,
is there any reason why you don't, afer creating the project, simply use
from the context menu Team -> Share Project?
Since you are also checking in .project I do not see any difference.
Norbert
Re: svn: Debug and Release under versioncontrol [message #159195 is a reply to message #159164] Mon, 28 November 2005 09:06 Go to previous messageGo to next message
Hi Toni,
so you are talking about the project name. Hmmm, you can't easily use the
same project content under differing names.
> I check out project/trunk into workspace trunk. Work there for a while.
Let me rewrite your usecase to the way I would do it:
- Check out the project from the repository as project to
..../workspace1/project
- Work there for a while
- For the minor fix, switch to a new workspace, e.g. .../workspace2 (or,
alternatively, start another instance of eclipse which uses workspace2).
- Check out the project again from the repository as project, now to
..../workspace2/project
- Do the fix and checkin.
And later, of course, merge the differences :-)
In short: Don't try to work on different versions of the same project in a
single workspace.
Hope this helps.
Norbert
Re: svn: Debug and Release under versioncontrol [message #159202 is a reply to message #159187] Mon, 28 November 2005 09:08 Go to previous messageGo to next message
> Hi Kurt,
> Norbert
I guess that is what I would like to use. But in my projct
this option is greyed out.
Doesn't it work with subversion?
/T
Re: svn: Debug and Release under versioncontrol [message #159302 is a reply to message #159202] Tue, 29 November 2005 03:26 Go to previous messageGo to next message
Toni,
now that's strange. I do it with subversion and never saw "share project"
greyed (unless the project was already shared, in which case there are all
those other nice context menu entries under Team :-)).
Guess I can't help you here.
Norbert
news:dmf30r$ul0$1@news.eclipse.org...
>> Hi Kurt,
>> Norbert
> /T
Re: svn: Debug and Release under versioncontrol [message #159333 is a reply to message #159302] Tue, 29 November 2005 10:15 Go to previous message
Ok, so the reason is that the project is already shared.
Thought the grand parent meant that with share you would
share the project info.
Thanks for the help in this thread. But I dont
know if I should report it as bugreport but I dont
think that the projectname should be in the .project file.
As of now I think that it doesn't work very good
when sharing a project with several developers.
You can get it workable with work-arounds but it
is quite cumbersome.
I would think that the goal should be that
a developer can check out the a project and press
build, run and debug without manually having to
do things.
/T
> Toni,
> Norbert
>>> Hi Kurt,
>>> Norbert
>> /T
Previous Topic:programmatically add target
Next Topic:no rule to make target
Current Time: Tue Jul 22 01:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.06077 seconds
