Home » Archived » BIRT » Charting in RCP application
Charting in RCP application [message #156407] Wed, 26 April 2006 14:45 Go to next message
Originally posted by: techjunkie01876.gmail.com
We are developing an enterprise application client in Eclipse RCP
framework. As part of it, we need to incorporate charts and graphs that
are clickable.
I am wondering if we can use BIRT charting framework for displaying charts
within an SWT composite. If so, what plugins out of BIRT are required? I'd
appreciate if anyone can point me to the right docs. Thanks.
Regards.
Re: Charting in RCP application [message #156667 is a reply to message #156407] Thu, 27 April 2006 03:41 Go to previous messageGo to next message
Yes, you can use the charting engine. For this configuration, you will need
those chart plugins and their dependents:
org.eclipse.birt.chart.device.swt
org.eclipse.birt.chart.engine
org.eclipse.birt.chart.engine.extension
org.eclipse.birt.core
org.apache.commons.codec
org.mozilla.rhino
You also need to get EMF core framework
All other dependent plugins are part of Eclipse
We are in the process of updating the chart documents, I'll let you know
when they are available.
David
"Pete" <techjunkie01876@gmail.com> wrote in message
news:7d0b86426a5ded455d56a7a3aef36150$1@www.eclipse.org...
> Hi
> are clickable.
> Regards.
Re: Charting in RCP application [message #156922 is a reply to message #156667] Thu, 27 April 2006 18:21 Go to previous messageGo to next message
Thanks David. I did manage to produce some charts within my RCP app. But,
find it very difficult to explore without proper docs. All BIRT docs talk
about chart builder tool and I am not sure that tool can be used for
creating charts within RCP app.
Re: Charting in RCP application [message #157073 is a reply to message #156922] Fri, 28 April 2006 07:23 Go to previous message
Pete,
Yes, you can use the chart builder, you will need a few more plugins in that
case
org.eclipse.birt.chart.ui
org.eclipse.birt.chart.ui.extension
org.eclipse.birt.core.ui
Please take a look at the org.eclipse.birt.chart.examples plugin for some
examples of Chart API use and Chart Builder use outside of BIRT reports.
This plugin has a lot of examples, and should cover most use cases, so it's
a good place to get started.
David
news:c760705a857bf203fc0b263fbe51740e$1@www.eclipse.org...
Previous Topic:Page Title of the Report
Next Topic:Parameter binding on chart as subreport
Current Time: Sat Jul 12 20:47:40 EDT 2025
Powered by FUDForum. Page generated in 0.02850 seconds
