Home » Language IDEs » Java Development Tools (JDT) » Re: Launch configurations should be stored in projects
Re: Launch configurations should be stored in projects [message #156398] Wed, 28 April 2004 18:17 Go to next message
Originally posted by: neil.neil.swingler.name
We share our project using Clearcase SCM. If I share a launch config and put
the .launch file in the project under version control, the other team
members don't automatically see the launch config, they have to explicitely
import it into their workspace. Not the end of the world I admit.
- Neil
Subject: Re: Launch configurations should be stored in projects
Date: 29 April 2004 00:58
Sorry, I don't understand your comment?
Darins
"Neil Swingler" <neil@neil.swingler.name> wrote in message
news:c6p8qf$a4e$1@eclipse.org...
> But even if the .launch file is stored in the project, it belongs to the
> workspace which is rather unintuitive.
> - Neil Swingler
> "Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
> news:c6j6s6$8es$1@eclipse.org...
> > As Pascal indicated, if you designate a launch configuration to be
shared,
> > you can specify the location.
> > See the Common tab for any launch configuration.
> > HTH
> > Darins
> > "Pascal Rapicault" <pascal@ibm.canada> wrote in message
> > news:c6iu2q$qma$1@eclipse.org...
> > > Launch configuration can be saved and then stored in the project.
> > > Look around in the launch configuration menu.
> > > PaScaL
> > > Juergen Weber wrote:
> > > > It seems that launch configurations are stored in
eclipse\workspace\.metadata\.plugins\org.eclipse.debug.core\ .launches
> > > > I think launch configurations should be part of the project, i.e. be
> in
> > > > the project tree.
> > > > If launch configurations contain long command line arguments, it is
> > > > cumbersome to enter them by hand. If they were part of the project,
> they
> > > > would be automatically imported on importing a project. Already now
a
> > > > launch configuration is attached to a project, so why should it not
be
> > > > part of the project?
> > > > What do you think, should I enter a bug?
> > > > Juergen
Re: Launch configurations should be stored in projects [message #156524 is a reply to message #156398] Thu, 29 April 2004 00:16 Go to previous message
Strange. I've used shared launch configs before (using CVS instead of
ClearCase, but that should be irrelevant for this) and they
automatically show up when I update from the repository - I never had to
import them (I don't even know how to go about importing launch configs).
Are you using 2.1 or the 3.0 branch of Eclipse?
Eric
I'm all in favor of keeping dangerous weapons out of the hands of fools.
Let's start with typewriters.
Previous Topic:Java SDK API documentation in Eclipse
Next Topic:Displaying API Documentation from within Eclipse
Current Time: Fri Jul 18 22:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.04117 seconds
