Home » Modeling » GMF (Graphical Modeling Framework) » Extract data from diagram
Extract data from diagram [message #156250] Thu, 18 October 2007 08:10 Go to next message
Originally posted by: giuseppeloprete.gmail.com
Hi all, I create an editor with GMF. When I create a file I can add nodes
and connections, they have some attributes to set and i set it. How can I
extract this attributes from the file generated with this editor? (when I
create a diagram I have 2 file: ".example" and ".example_diagram", I need
to extract data from ".example")
Thanks all,
Cheers
Re: Extract data from diagram [message #156264 is a reply to message #156250] Thu, 18 October 2007 08:54 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
you want to access this data in your editor or in order to generate
artifacts?
- -stefan
> nodes and connections, they have some attributes to set and i set it.
> How can I extract this attributes from the file generated with this
> editor? (when I create a diagram I have 2 file: ".example" and
> ".example_diagram", I need to extract data from ".example")
> Thanks all,
> Cheers
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHF1eEIYVWjMSpDwwRAingAJ9CNW6dZ41mnPh27T4ePhuwHekslwCc CT2A
BRM9VIGkGJiBNQgEnIn2Uxw=
=G1Bf
-----END PGP SIGNATURE-----
Re: Extract data from diagram [message #156279 is a reply to message #156264] Thu, 18 October 2007 09:12 Go to previous messageGo to next message
in order to generate artifacts. I must generate a html document that
contains information about this diagram.
Cheers
Re: Extract data from diagram [message #156283 is a reply to message #156279] Thu, 18 October 2007 09:27 Go to previous messageGo to next message
Originally posted by: dennis.huebner.gmail.com
Hi giuseppe,
If you are using oAW it's pretty simple!
Just look at
http://www.eclipse.org/articles/Article-FromFrontendToCode-M DSDInPractice/article.html
regards,
Dennis.
> Cheers
Re: Extract data from diagram [message #156302 is a reply to message #156283] Thu, 18 October 2007 10:42 Go to previous messageGo to next message
In which part of tutorial they extract attributes from diagram?
Re: Extract data from diagram [message #156310 is a reply to message #156302] Thu, 18 October 2007 10:49 Go to previous messageGo to next message
Hash: SHA1
giuseppe, you want to generate code out of the model. I won't suggest
you to start with this tutorial but rather look for easier tutorials on
the oAW website www.openarchitectureware.org .It's an eclipse project,
so you'll find doc about it on www.eclipse.org/gmt, too.
- -stefan
iD8DBQFHF3JjIYVWjMSpDwwRAsgLAJ9xMxRs3vR85Bk64CloTtEmJoRyMQCg iykA
TG18/DTI6A6hcSLczovxd2I=
=xsWE
Re: Extract data from diagram [message #156370 is a reply to message #156302] Fri, 19 October 2007 02:53 Go to previous message
In "Workflow Definition"- Part,
but not just attributes hole model (locate in ${modelFile}) will be
readed, so you can easy access all instances (also attributes) in your
template files.
Dennis.
Previous Topic:GMF Prosheet Customization
Next Topic:problems removing elements
Current Time: Sun Jul 27 00:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.04609 seconds
