Home » Language IDEs » C / C++ IDE (CDT) » cdt Code Assist and macros
cdt Code Assist and macros [message #156213] Fri, 14 October 2005 09:58 Go to next message
The CDT FAQ says
any macro's necessary to read stdio.h are set (often a missing macro will
cause a system header to encounter a #error in the header file -- for
example on windows using cygwin, the defining the symbol __i386__ will
allow stdio.h to be understood)
unfortunately it is not always aceptable to add a #define to the source
code
many IDEs and editors solve this problem by allow the user to specify a
set of predefined macros, but I failed to locate such a facility in CDT
in othercases compilers predefine macro to indicate which compiler and
version is in play, in my case such a solution would also be acceptable
but I was not able to locate the name of such a macro
if it exists I could add some thing like the following to may files:
#ifdef __ECLIPSE_CDT_COMPILER
#define MY_MACRO
#endif
Re: cdt Code Assist and macros [message #156223 is a reply to message #156213] Fri, 14 October 2005 11:50 Go to previous message
Jens Odborg wrote:
> The CDT FAQ says
> will cause a system header to encounter a #error in the header file --
> for example on windows using cygwin, the defining the symbol __i386__
> will allow stdio.h to be understood)
> code
This facility exists in the CDT.
-- Open the project properties window.
-- Select C/C++ Include Paths & Symbols.
-- Click on the button labeled Add Preprocessor Symbol.
-- Type in the symbol you want to define, followed optionally by '=' and
the value you want for that symbol.
> #define MY_MACRO
> #endif
Previous Topic:Multiple projects on common src directory
Next Topic:debug error viewing linked structs
Current Time: Thu May 08 04:16:18 EDT 2025
Powered by FUDForum. Page generated in 0.03127 seconds
