Home » Eclipse Projects » GEF » Getting GEF Example to work seems pretty confusing task
Getting GEF Example to work seems pretty confusing task [message #156207] |
Sun, 31 October 2004 01:40  |
Originally posted by: nikivancic.yahoo.com
While I am very recent Eclipse "fan", I am by no means a novice. However,
after many hours of trying to comply with the instructions found on
www.eclipse.org/wep, I had to give up and ask for advice here. While doing
that, I would also like to contribute with some of my experience, that may
result with easy improvements :-)
I decided not to use the proposed location for the Workspace, when run
Eclipse for the first time - instead I opted to place it somewhere outside
Eclipse's tree. That resulted with a large number of difficulties,
indicating perhaps that such configuration may not have been given it's fair
share of testing. Trying to save my time figuring all these problems (which
I may enumerate in a different context), I removed the Eclipse and started
afresh.
Installing it the second time (really just expanding the archive at the
location of my preference), I also kept the default location for the
workspace, and the very first thing I tried was to add some additional
plugins, using the Eclipse's own UI (Help -> Software Updates -> Find and
Install menu item). This resulted with a number of additional features,
which I all accepted (These included the GEF and VE - which I was after. The
"Update Wizard" initiated the download, and that resulted with the first
problem:
1. Each of the selected features, is preceeded with the dialog warning that
the requested "package" is not signed, giving me the chance to reject it.
This is very inconvenient, since there is not a global override of such
control - one has to sit next to the keyboard and continue accepting the
stuff that was specifically selected in the first step of the Wizard.
Besides, why are these features not signed, then ?
Next, reading randomly throught various Eclipse newsgroups I realized that
many users complain that Eclipse will not recognize the newly added
features. There is a reference somewhere to run the Eclipse with an
additional argument (-clean if I remember it right), something no too
convenient using a desktop based link to the eclipse.exe. I also found the
alternative (if it realy is), accessible via Product Configuration Dialog,
which offers the service "Search for updates for all installed features".
This leads to the second inconvenience:
2. Using the "Search for updates for all installed features" results in a
(potentially) circular situation, as I got each time the offer to install
something different than what I already had for EMF SDK and the Examples for
EMF. The last versions offered to me were 2.0.1.R200409171617 - certainly
different from what I started when updating the initial configuration.
3. My real aim was to try one of the GEF examples, after reading all that
was available from www.eclipse.org/wep, (except the book referenced there).
Realizing that I do have all that's needed already installed (at least I
think so):
10/30/2004 07:50 PM <DIR> org.eclipse.gef.doc.isv_3.0.1
10/30/2004 07:49 PM <DIR> org.eclipse.gef.examples.flow_3.0.1
10/30/2004 07:49 PM <DIR> org.eclipse.gef.examples.logic_3.0.0
10/30/2004 07:49 PM <DIR> org.eclipse.gef.examples.source_3.0.1
10/30/2004 07:50 PM <DIR> org.eclipse.gef.source_3.0.1
10/30/2004 07:49 PM <DIR> org.eclipse.gef_3.0.1
I tried the instructions from the WEP FAQ page, which specifically says:
a.. How do I Run the Logic Example?
Download the example that matches your version of GEF. Exit Eclipse and
unzip into the eclipse directory. Restart Eclipse and verify it was
installed by going to Help->About Eclipse Platform->Plug-in Details and
checking for Logic GEF Example in the list. Next, create a simple Project.
Then run the Logic Wizard. The wizard can be found at File->New->Other
(Control+N), under the Examples heading. Select the simple project as the
container in which the wizard will place the example document. The document
should open automatically when you press Finish.
This is a very confusing paragraph since each of the instructions can be
interpreted more then one way. Rather than discussing semantics here, I will
just say that I am still not able to do anything with these instruction -
anything more than getting a simple project, whose contents would be a
..project file and flowExample2.flow file in the case I selected the Flow
Diagram example as suggested in the FAQ.
Can someone explain what's going on here? Should I have selected a project
of a different type as a container? I tried that to no avail.
Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156456 is a reply to message #156207] |
Mon, 01 November 2004 13:05   |
Once you have created a project, go to File -> New -> Examples and then pick
the GEF example (logic, flow or shapes) that you want to create.
"Nik Ivancic" <nikivancic@yahoo.com> wrote in message
news:cm21cd$882$1@eclipse.org...
fair
(which
> afresh.
The
> problem:
that
for
there).
> think so):
Project.
document
will
> Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156533 is a reply to message #156456] |
Mon, 01 November 2004 19:27   |
That is exactly what I did. Very precisely:
1. From the File->New->Project... wizard, I created the empty Java project.
The Navigator view
shows the presence of the .classpath and .project files only.
2. From the File->New->Example ... I selected the New Example Wizard. On
it's treeview
I further selected the GEF (Graphical Editing Framwork), Node expanded it
and selected the
Flow Diagram entry
3. Using all of the remaining defaults I finished the Wizard. As a result.
my TestGEF project folder
contents increased by a single file - flowExample2.flow, which is also
displayed in the Graphical
Editor under the title GEF Flow Example, together with the mathcing Palette.
No code of any kind - despite the fact that the peek into Plugins folder of
Eclipse shows all needed stuff.
What am I doing wrong, Pratik?
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cm5tt8$aqf$1@eclipse.org...
> pick
>> doing
>> may
>> outside
> fair
> (which
>> started
>> afresh.
> The
>> problem:
> that
>> that
>> the
>> Dialog,
> for
> there).
>> think so):
> Project.
> document
> will
>> project
>> Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156590 is a reply to message #156533] |
Tue, 02 November 2004 14:39   |
What are you trying to do? You want to see the code for the example and
GEF?
news:cm6k9b$g4g$1@eclipse.org...
project.
> The Navigator view
> it's treeview
> and selected the
> Flow Diagram entry
Palette.
of
> > pick
However,
> >> doing
> >> may
> >> outside
> > fair
> > (which
> >> started
> >> afresh.
and
after.
> > The
first
> >> problem:
> > that
it.
the
> >> that
> >> the
> >> Dialog,
features".
a
install
Examples
> > for
certainly
that
> > there).
I
> >> think so):
says:
and
> > Project.
the
> > document
be
> > will
instruction -
Flow
> >> project
> >> Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156599 is a reply to message #156533] |
Tue, 02 November 2004 15:38   |
You said you wanted to run that example. If you want to look at or modify
its code, you need to import the plugins into your workspace. Right-click
in the Package Explorer, and select Import -> External Plugins and
Fragments.
project.
> The Navigator view
> it's treeview
> and selected the
> Flow Diagram entry
Palette.
of
> > pick
However,
> >> doing
> >> may
> >> outside
> > fair
> > (which
> >> started
> >> afresh.
and
after.
> > The
first
> >> problem:
> > that
it.
the
> >> that
> >> the
> >> Dialog,
features".
a
install
Examples
> > for
certainly
that
> > there).
I
> >> think so):
says:
and
> > Project.
the
> > document
be
> > will
instruction -
Flow
> >> project
> >> Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156628 is a reply to message #156599] |
Tue, 02 November 2004 16:54   |
Thanks, Pratik - I thought so too. However, I was mislead by the GEF FAQ #
3,
posted at http://www.eclipse.org/gef/, which specifically states:
It would be a good idea to correct the above paragraph, as there will likely
be others who
will be as confused as I was.
news:cm8r71$iie$1@eclipse.org...
> Fragments.
> project.
>> The Navigator view
>> it's treeview
>> and selected the
>> Flow Diagram entry
>> result.
> Palette.
> of
>> > pick
> However,
>> >> doing
>> >> may
>> >> outside
>> >> it's
>> > fair
>> > (which
>> >> started
>> >> afresh.
>> >> the
> and
>> >> features,
> after.
>> > The
> first
>> >> problem:
>> > that
> it.
>> >> such
> the
>> >> that
>> >> the
>> >> Dialog,
> features".
>> >> in
> a
> install
> Examples
>> > for
> certainly
> that
>> > there).
> I
>> >> think so):
> says:
> and
>> >> and
>> > Project.
> the
>> > document
> be
>> >> I
>> > will
> instruction -
> Flow
>> >> project
>> >> Thanks in advance
Re: Getting GEF Example to work seems pretty confusing task [message #156666 is a reply to message #156628] |
Wed, 03 November 2004 11:23  |
The importart word here being "Run".
Project.
document
likely
> be others who
Current Time: Tue Jul 22 09:37:36 EDT 2025
Powered by FUDForum. Page generated in 0.14894 seconds
