Home » Eclipse Projects » GEF » Adding marquee selection to SelectionTool
Adding marquee selection to SelectionTool [message #156142] Fri, 29 October 2004 17:19 Go to next message
Greetings,
I have noticed that the Selection tool used in the logic example also
carries "Marquee" drag functionality when you click and drag on a canvas.
However, the default behaviour doesn't seem to do this. How would I add
this? I can't seem to find the example code that does it.
I tried setting a MarqueeDragTracker on the SelectionTool, but doing in
the createTool call on an entry throws an exception in
AbstractTool.activate, so I assume this approach is either incorrect or
being done too early.
--Cam
Re: Adding marquee selection to SelectionTool [message #156453 is a reply to message #156142] Mon, 01 November 2004 12:25 Go to previous messageGo to next message
Does anyone have an idea this?
Cameron
Cameron Bateman wrote:
> Greetings,
> --Cam
Re: Adding marquee selection to SelectionTool [message #156461 is a reply to message #156453] Mon, 01 November 2004 13:39 Go to previous messageGo to next message
The default behaviour already does that. All you need to do is add a
PanningSelectionToolEntry to your palette.
"Cameron Bateman" <cbateman@rim.com> wrote in message
news:cm5ric$6iu$1@eclipse.org...
> Cameron
> > Greetings,
canvas.
> > --Cam
Re: Adding marquee selection to SelectionTool [message #156475 is a reply to message #156461] Mon, 01 November 2004 14:04 Go to previous messageGo to next message
Hi Pratik,
Thanks for your response. I am adding the PanningSelectionToolEntry as
you say, but when I try to click and drag on my canvass with the tool, it
just sets the "invalid mode" mouse pointer (circle with a cross through
it) as though a request is being rejected.
Is it possible that I'm inadvertently overriding the default behaviour?
The marquee tool _does_ work. The code that creates the pallette entries
looks like this:
_paletteRoot = new PaletteRoot();
// group the default controls
PaletteGroup controls = new PaletteGroup("Controls");
// selection tool
PanningSelectionToolEntry toolEntry = new PanningSelectionToolEntry();
controls.add(toolEntry);
_paletteRoot.setDefaultEntry(toolEntry);
// Marquee (group selection) tool
controls.add(new MarqueeToolEntry());
_paletteRoot.add(controls);
--Cam
> > Thanks,
> > Cameron
> > > Greetings,
> canvas.
> > > --Cam
Re: Adding marquee selection to SelectionTool [message #156487 is a reply to message #156475] Mon, 01 November 2004 14:37 Go to previous messageGo to next message
Set a breakpoint in SelectionTool#handleButtonDown() and see what's going
on. You can compare it to our examples to see what should be happening.
What is the target edit part that is determined in this method? And what is
its drag tracker?
news:cm61bk$h3i$1@eclipse.org...
> Hi Pratik,
> looks like this:
> // selection tool
> --Cam
> > > Thanks,
> > > Cameron
> > > > Greetings,
also
> > canvas.
add
in
or
> > > > --Cam
Re: Adding marquee selection to SelectionTool [message #156491 is a reply to message #156475] Mon, 01 November 2004 14:50 Go to previous messageGo to next message
It sounds like you are attempting to drag your contents editpart. You
should return NULL or the marquee drag tracker in your getDragTracker(req)
method. See LogicDiagramEditPart for an example.
> Hi Pratik,
> looks like this:
> // selection tool
> --Cam
> > > Thanks,
> > > Cameron
> > > > Greetings,
also
> > canvas.
add
in
or
> > > > --Cam
Re: Adding marquee selection to SelectionTool [message #156503 is a reply to message #156491] Mon, 01 November 2004 15:09 Go to previous messageGo to next message
Yep, that did it! Thanks. One follow-up: with the selection tool working
in this way, is there any further functionality in the Marquee tool that
makes it worth keeping on my palette?
--Cam
> > Hi Pratik,
> > looks like this:
> > // selection tool
> > --Cam
> > > > Thanks,
> > > > Cameron
> > > > > Greetings,
> also
> > > canvas.
> add
> in
> or
> > > > > --Cam
Re: Adding marquee selection to SelectionTool [message #156523 is a reply to message #156503] Mon, 01 November 2004 16:58 Go to previous message
No.
news:cm6551$o42$1@eclipse.org...
> --Cam
Previous Topic:Polyline.setPoints()
Next Topic:Creating a table
Current Time: Sat May 10 18:45:36 EDT 2025
Powered by FUDForum. Page generated in 0.04002 seconds
