Home » Language IDEs » ServerTools (WTP) » Does XDoclet work for you with WTP M200601102004 (aka R1.0.1 alpha) ?
Does XDoclet work for you with WTP M200601102004 (aka R1.0.1 alpha) ? [message #156002] Wed, 11 January 2006 21:51
If you have downloaded from :
http://download.eclipse.org/webtools/downloads/drops/M-M2006 01102004-200601102004/
Can you confirm if XDoclet is working for you ? and which XDoclet
runtime are you using.
I'm thinking it must me, I must have incorrectly configured something,
but I just can't find anything wrong. My manual xdoclet script still
works on my project and I upgraded using the same method I normally use.
I am using 1.3-SNAPSHOT as I need Java5 support, this is provided by a
plugin knocked up for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116145 and it does appear
to be working since its displayed in the tabs.
However I'm getting the dreaded errors again:
Buildfile:
/home/dlm/workspace/.metadata/.plugins/org.eclipse.jst.j2ee. ejb.annotations.xdoclet/tempAnt.xml
init:
webdoclet:
BUILD FAILED
/home/dlm/workspace/.metadata/.plugins/org.eclipse.jst.j2ee. ejb.annotations.xdoclet/tempAnt.xml:56:
/home/dlm/workspace/.metadata/.plugins/org.eclipse.jst.j2ee. ejb.annotations.xdoclet/${xdoclet.home}
not found.
Total time: 643 milliseconds
Darryl
Previous Topic:Getting off the ground with WTP 1.0
Next Topic:xml format and big files
Current Time: Tue Jul 22 11:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
