Home » Eclipse Projects » GEF » Popup menu problem
Popup menu problem [message #155881] Wed, 27 October 2004 10:12 Go to next message
We have a set of popup-menus created in two ways: (1) in java, via the action-registry, i.e., not
plugin.xml; (2) via plugin.xml, using objectContribution, i.e., not via the action-registry. Both
sets of popup-menu items work fine.
Now we want to add other items via the plugin.xml, using viewerContribution -- that fails. The
item(s) appear in the popup-menu, but are *never* enabled, and in fact no code in their class(es) is
ever called. What mistake are we making? Or does GEF not play with viewerContribution?
Here is the XML; the class="refactor.actions.diagram.EditorSplitter" does exist, and the
targetID="editors.modifiers.diagram.diagramcontextmenu" is registered, using
IWorkbenchPartSite.registerContextMenu():
<viewerContribution
id="refactor.diagramViewer">
<action
label="&amp;Split..."
menubarPath="additions"
enablesFor="1"
id="refactor.diagramSplitAction">
</action>
</viewerContribution>
thanks,
Paul
Re: Popup menu problem [message #155889 is a reply to message #155881] Wed, 27 October 2004 10:51 Go to previous message
I think that a contextmenu in GEF is nothing more than a JFace MenuManager,
which is attached to an EditPartViewer's Control.
You should try debugging ActionContributionItem/MenuManager to see what is
really behind that MenuItem, and why it is disabled.
"Paul Keyser" <rolarenfan@earthlink.net> wrote in message
news:cloa1u$7fb$1@eclipse.org...
viewerContribution?
exist, and the
using
> <viewerContribution
> <action
> enablesFor="1"
> </action>
> thanks,
> Paul
Previous Topic:Create a block arrow
Next Topic:Problem with DelegatingLayout
Current Time: Sat Jul 26 14:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
