Home » Language IDEs » ServerTools (WTP) » xml editor and validate context menu
xml editor and validate context menu [message #155667] Tue, 10 January 2006 10:19 Go to next message
Originally posted by: Matthias.Dillier.snb.ch
Hi all
I have to questions fo the xml editor in wtp.
What do I need for a minimal installation, when I only want to use the
xml-part of wtp (xml and dtd editors and validators)?
I have files with an extension other then .xml. They are opened by the
xml-editor but there is no validate entry in the content menu in the
package explorer for these files. How can I correct this?
Thank you for any help
Matthias Dillier
Re: xml editor and validate context menu [message #156462 is a reply to message #155667] Fri, 13 January 2006 21:36 Go to previous message
On Tue, 10 Jan 2006 10:19:54 -0500, Matthias Dillier <Matthias.Dillier@s=
> What do I need for a minimal installation, when I only want to use the=
Basically the xml_core/ui.feature(s) common_core/ui.features(s)
and all they prereq (still gef, emf, and jem, so far).
We don't readily provide this as an install option right now, but
if you wanted to sort through the feature.xml's, etc., you could do so.
These ae also (mostly) documented in
http://www.eclipse.org/webtools/development/arch_and_design/ subsystems/S=
ubsystemsAndFeatures.html
> I have files with an extension other then .xml. They are opened by the=
Sorry, validation is not currently content type sensitive. The only "hac=
k-like" solution
now is to grep the plugin.xml's, find where xml validation is defined, a=
nd add your extention
there [again, this is only for those not feint of heart, I'm not suggest=
ing "end users"
do this .. just if you are experimenting with providing your own plugin,=
etc.
Previous Topic:tutorial:building a school schedule web application
Next Topic:Full Build on XML or JSP edit?
Current Time: Fri Jul 25 01:48:43 EDT 2025
Powered by FUDForum. Page generated in 0.35615 seconds
