What will AST ultimately support? [message #155456] |
Wed, 21 April 2004 17:37  |
Will(does) AST handle code formatting, taking into account the user's
coding style preferences?
Will current refactorings (like generate getters and setters) be ported
to use AST instead of plain string concatenation?
Guillaume
Re: What will AST ultimately support? [message #155640 is a reply to message #155591] |
Thu, 22 April 2004 16:47   |
Ok, that's good news. Can you point me to an example of AST code
manipulation? I am currently struggling to find an IDocument instance to
apply the changes generated by ASTRewriter... But maybe there is another
way?
Guillaume
Charles-Philip Bentley wrote:
> I have been doing some custom refactorings myself in my plug-in and i
> work exclusively with ASTs. It is so much easier IMO.
> However there is an issue. You can't "Edit-->Undo" a whole refactoring
> with AST. You only Undo AST modifications. So if you do 10 AST
> modifications for a refactoring, you will have to do "Edit-->Undo" 10
> times to completely undo the refactoring/structure modification.
> Charles
> Guillaume Pothier wrote:
>> Yeah, I should have said code manipulation instead of refactorings.
>> Thanks for the pointer to ASTRewrite.
>> So, is the new AST designed to handle all code manipulation? Or will
>> there sill be a need for plain-text code assembly?
>> g
>>>> Hi,
>>>> user's coding style preferences?
>>>> ported to use AST instead of plain string concatenation?
>>>> Guillaume
>>> fyi,
>>> 'generate getters and setters' is not implemented as a refactoring
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=37820
>>> yes, use ASTRewrite and your prefs should be respected. if not, enter
>>> a bug report.
>>> a.
Re: What will AST ultimately support? [message #155720 is a reply to message #155640] |
Fri, 23 April 2004 06:08  |
Hi Gui
I have been told to do that
import org.eclipse.jface.text.Document;
IDocument idoc= new Document(icu.getSource());
where icu is an ICompilationUnit.
Otherwise you can get an IDocument from the active EditorPart
AbstractTextEditor ate = (AbstractTextEditor) _part;
FileEditorInput fe = (FileEditorInput) _part.getEditorInput();
IDocument idoc = ate.getDocumentProvider().getDocument(fe);
But that only works for me when inside the Java Editor (ie _part is not
null)
> way?
> Thanks
> Guillaume
>> Charles
>>> g
>>>>> Hi,
>>>>> Guillaume
>>>> fyi,
>>>> enter a bug report.
>>>> a.
Re: What will AST ultimately support? [message #155728 is a reply to message #155720] |
Fri, 23 April 2004 05:49  |
Hehe thanks!
> Hi Gui
> null)
>> to apply the changes generated by ASTRewriter... But maybe there is
>> another way?
>> Thanks
>> Guillaume
>>> refactoring with AST. You only Undo AST modifications. So if you do
>>> 10 AST modifications for a refactoring, you will have to do
>>> "Edit-->Undo" 10 times to completely undo the refactoring/structure
>>> modification.
>>> Charles
>>>> g
>>>>>> Hi,
>>>>>> Guillaume
>>>>> fyi,
>>>>> enter a bug report.
>>>>> a.
FUDForum. Page generated in 0.11198 seconds
