Home » Eclipse Projects » DTP » Derby plugin features for Callisto release
Derby plugin features for Callisto release [message #14561] Tue, 16 May 2006 20:33
Originally posted by: anil.samuel.gmail.com
Can I presume the following are the Derby DTP plugin features available
by Callisto (June 30) release. Please add if I missed out anything or
remove if not included for the release.
1 Connection Profile to connect to a Derby instance
[- no GUI to administer, ie, to startup or shutdown) an instance]
2 DSE to list Dependencies, Sequences, Stored Procedures, Tables, UDFs,
UDTs and Views at Schema level
3 DSE to list Dependencies at Stored Procedure level
4 DSE to list Dependencies, Columns, Constraints, Indexes, Triggers at
Table level
5 DSE to list Dependencies at UDF level
6 DSE to list Dependencies at UDT level
7 DSE to list Dependencies, Columns, Triggers at View level
[- no GUI to create/modify/delete any database objects except routines
such as Stored Procedure, UDF and Trigger]
8 Right-click/Edit popup menu for Routines
9 RoutineEditor for Routines
10 Right-click/Run popup menu for Routines
11 Configure input paramters for Routines
12 SQL Result View to view the result of Run.
*UDF - User Defined Function
*UDT - User Defined Type
Anthos
Previous Topic:ParameterInOutWrapper
Next Topic:Derby plugin features for Callisto release
Current Time: Tue Jul 08 13:08:20 EDT 2025
Powered by FUDForum. Page generated in 0.05478 seconds
