Exception in org.eclipse.core.internal.compatibility.PluginActivator.stop() - unable to start Eclips [message #155083] |
Tue, 20 April 2004 02:32 |
Originally posted by: mehow.remove.neurosoft.net
Hi there,
I was trying to load a huge file inside Eclipse, which resulted in the
"out of memory" error and I was forced to close the workbench.
Now, whenever I am trying to start it, the get the message containing
only the path to the log file. Eclipse won't start. The log file
contains the lines below. Can I do anything to make it work again
(except for reinstalling it from scratch)?
Any help will be appreciated
Michal
!ENTRY reference:file:c:/Documents and Settings/mehow.NEUROSOFT/My
Programs/Eclipse 3.0M8/plugins/org.eclipse.debug.core_3.0.0/ 0 0 kwi 19,
2004 14:34:51.156
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.stop ()
org.eclipse.osgi.framework.internal.core.BundleContext.stop( BundleContext.java:1044)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:482)
org.eclipse.osgi.framework.internal.core.Bundle.suspend(Bund le.java:546)
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1000)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.decF WSL(StartLevelImpl.java:626)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.doSe tStartLevel(StartLevelImpl.java:277)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.shut down(StartLevelImpl.java:250)
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:196)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:441)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.java:181)
at java.lang.Thread.run(Thread.java:534)
Nested exception:
org.eclipse.debug.internal.core.LaunchManager.shutdown(Launc hManager.java:482)
at org.eclipse.debug.core.DebugPlugin.shutdown(DebugPlugin.java :435)
org.eclipse.core.internal.compatibility.PluginActivator.stop (PluginActivator.java:66)
org.eclipse.osgi.framework.internal.core.BundleContext$2.run (BundleContext.java:1028)
org.eclipse.osgi.framework.internal.core.BundleContext.stop( BundleContext.java:1024)
FUDForum. Page generated in 0.03450 seconds
