Unable to use debuger [message #155044] |
Mon, 26 September 2005 04:09 |
Originally posted by: pgodiani.axway.com
Hi all,
I face some severe problems using Eclipse 3.1 + CDT 3.0 on my Fedora 3:
I'm totally unable to use the debugging features of the tool.
When selecting Run/Debug and trying to create some 'C/C++ local
application'
configuration, I always get the same 'An error has occurred...' popup. The
error seems to tell some class is missing, but I did install CDT as
required.
Please help :-(
!ENTRY org.eclipse.jface 4 2 2005-09-26 10:04:32.358
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/cdt/debug/core/CDebugCorePlugin
org.eclipse.cdt.launch.ui.CDebuggerTab.loadDebuggerComboBox( CDebuggerTab.java:187)
org.eclipse.cdt.launch.ui.CDebuggerTab.initializeFrom(CDebug gerTab.java:248)
org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.ini tializeFrom(AbstractLaunchConfigurationTabGroup.java:86)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:543)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$5.run(LaunchConfigurationTabGroupVi ewer.java:471)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:488)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:452)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:789)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$3.selectionChanged(LaunchConfigurationsDia log.java:601)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:763)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
FUDForum. Page generated in 0.03069 seconds
