Home » Modeling » GMF (Graphical Modeling Framework) » OWL export
OWL export [message #154969] Fri, 12 October 2007 06:21 Go to next message
Originally posted by: tom.tom.com
I have a gmf-generated editor, and I would like to export the .model files
users create, and export them to OWL. I tried to use the EODM Ecore2OWL
but that of course works on ecore files. Is there a quick way to convert
the .model files into ecore format?
Thanks very much!
Tom
Re: OWL export [message #155008 is a reply to message #154969] Fri, 12 October 2007 07:20 Go to previous messageGo to next message
Tom,
I'm not sure this even makes sense. Ecore will be the meta model for
your instance file and it just doesn't seem to make sense to want to
convert an instance to a meta instance...
Tom wrote:
> files users create, and export them to OWL. I tried to use the EODM
> Ecore2OWL but that of course works on ecore files. Is there a quick
> way to convert the .model files into ecore format?
> Thanks very much!
> Tom
Re: OWL export [message #155132 is a reply to message #155008] Fri, 12 October 2007 11:28 Go to previous messageGo to next message
Ed et al.,
OK, I *thought* ecore format allowed meta-statements and instance
statements, so I was wrong. The XMI format in the .model files would, I
guess, have to be converted to OWL. Alternatively, my
ModelDocumentProvider could additionally walk the model and emit OWL?
Thanks again,
Tom
Ed Merks wrote:
> Tom,
> Tom wrote:
>> Thanks very much!
>> Tom
Re: OWL export [message #155182 is a reply to message #155132] Sat, 13 October 2007 06:42 Go to previous messageGo to next message
Tom,
I really don't know enough about OWL to say anything intelligent about
what you are trying to do.
Tom wrote:
> Ed et al.,
> I guess, have to be converted to OWL. Alternatively, my
> Thanks again,
> Tom
> Ed Merks wrote:
>> Tom,
>> for your instance file and it just doesn't seem to make sense to want
>> to convert an instance to a meta instance...
>> Tom wrote:
>>> Hi,
>>> Thanks very much!
>>> Tom
Re: OWL export [message #155204 is a reply to message #155182] Sat, 13 October 2007 11:53 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
I am building several gmf editors to work with an enormous OWL file.
Maybe I can help with any questions?
Tomas
Ed Merks wrote:
> Tom,
> Tom wrote:
>> Ed et al.,
>> Thanks again,
>> Tom
>> Ed Merks wrote:
>>> Tom,
>>> Tom wrote:
>>>> Hi,
>>>> Thanks very much!
>>>> Tom
Re: OWL export [message #155211 is a reply to message #155132] Sat, 13 October 2007 15:11 Go to previous messageGo to next message
Tom,
Is there any chance that the following use case may be of some help
here:
http://www.eclipse.org/m2m/atl/usecases/ODMImplementation/
Jean
"Tom" <tom@tom.com> a
Re: OWL export [message #155289 is a reply to message #155211] Mon, 15 October 2007 07:28 Go to previous messageGo to next message
Thanks everyone for the input!
Jean: Thanks very much for the link. That use case seems relevant, since
it includes the instance "Pablo Picasso" in the OWL export (is that M0
level?)
Tomas: Thanks for the offer of help! How do you "bridge" back to the
triple store? Could you point me to the parts of gmf that you customized?
Tom
Jean.Bezivin wrote:
> Tom,
> here:
> Best regards,
> Jean
Re: OWL export [message #155336 is a reply to message #155289] Mon, 15 October 2007 08:05 Go to previous message
Well, my case may be different than yours.
In my model elements, I wrap OntologyClasses relating to the triple
store (I produce these classes with predefined methods). Then I do a lot
of handling to make sure that relations and properties are set correctly.
> level?)
> Cheers,
> Tom
> Jean.Bezivin wrote:
>> Tom,
>> here:
>> Best regards,
>> Jean
Previous Topic:popup "the chosen operation is not currently available"
Next Topic:"save failed" exception triggered by shipped GMF code
Current Time: Mon Sep 01 00:03:12 EDT 2025
Powered by FUDForum. Page generated in 0.07227 seconds
