CTags not found or in path? Which path? [message #154948] |
Fri, 23 September 2005 00:14  |
I have exuberant-ctags in my /usr/bin. My cdt always complain about
CTags not found on path or not installed.
I do not specify the binary explicitly but use default in the indexer
settings.
What path is it looking for? Any ideas?
Re: CTags not found or in path? Which path? [message #155231 is a reply to message #155138] |
Wed, 28 September 2005 01:37   |
Something new I've noticed is that when the ctags file gets very big, I
get a NegativeArrayException whenever I ask for a completion. Deleting
the file, fixes it till next time...
John Camelon wrote:
> Alwyn Schoeman wrote:
>> Hi Norbert,
>> ctags yield command not found. Maybe what I need is a link between
>> ctags and exuberant-ctags...
>> Norbert Ploett wrote:
>>> Alwyn,
>>> if you start a command shell on your system, type "ctags" and it
>>> works then it should work from eclipse, too. Eclipse also just starts
>>> a new shell and, when no path is given, calls ctags without explicit
>>> path. The "path" is simply the standard command search path.
>>> Can you confirm this?
>>> Norbert
>>> "Alwyn Schoeman" <alwyn.schoeman@gmail.com> schrieb im Newsbeitrag
>>> news:dgvvsp$58t$1@news.eclipse.org...
>>>> Hi,
>>>> settings.
> Make sure that 'which ctags' yields you the exuberant one, and restart
> Eclipse.
> JC
Re: CTags not found or in path? Which path? [message #155518 is a reply to message #155231] |
Fri, 30 September 2005 14:06  |
Sounds like a good bug for bugzilla...
FUDForum. Page generated in 0.05314 seconds
