compare with file outside workspace [message #154935] |
Thu, 01 June 2006 19:59 |
Originally posted by: wharley.bea.com
I have a text file (foo.html) within a project in my workspace. Someone has
sent me a modified version of the file, so the modified version is now
sitting in a directory on my hard disk, outside of the workspace.
I would like to compare the two. How do I do this, in Eclipse 3.2? I've
searched Help and the FAQ, as well as this newsgroup, and I'm sure the
answer is there somewhere but I can't seem to find it.
Thanks!
Re: compare with file outside workspace [message #154955 is a reply to message #154935] |
Fri, 02 June 2006 06:43 |
Originally posted by: tom_eicher.ch.ibm.com
Hi Walter,
you can't do it directly as the support for external files is somewhat
minimal... You have the following choices:
- copy the file into a different location in your workspace and compare
the two files
- replace your workspace copy with the external one and use compare with
.... local history to see the changes.
-tom
> Thanks!
FUDForum. Page generated in 0.07809 seconds
