Home » Archived » BIRT » How to suppress duplicate data
How to suppress duplicate data [message #154689] Thu, 20 April 2006 06:07 Go to next message
Originally posted by: riannacmw.yahoo.com.hk
My report contains two column list. Some data in column 2 duplicate with
that in the next row. How can I suppress the duplicate? i.e to display a
blank space for the duplicate data.
Rianna
Re: How to suppress duplicate data [message #154904 is a reply to message #154689] Thu, 20 April 2006 12:16 Go to previous messageGo to next message
Rianna,
I just build a report off the sample db that list all the OrderDetails.
The first column is the order number which is repeated for every entry.
To suppress this I did the following:
On the Table or List, click the script tab and select the onPrepare method.
put in the following
ordernumberlast = "";
Then in the expression builder for the order number change the value to:
if( row["ORDERNUMBER"] == ordernumberlast ){
valtodisp ="";
}else{
ordernumberlast = row["ORDERNUMBER"];
This should work.
Jason
"Rianna" <riannacmw@yahoo.com.hk> wrote in message
news:c73132fdf518f83550c789b01f767d90$1@www.eclipse.org...
> Hello,
> Rianna
Re: How to suppress duplicate data [message #154982 is a reply to message #154689] Thu, 20 April 2006 17:20 Go to previous messageGo to next message
Originally posted by: dolphycj.xxxxxxxxx.com
You may also want to look into Drop columns.
Re: How to suppress duplicate data [message #155012 is a reply to message #154904] Thu, 20 April 2006 21:27 Go to previous message
Thank you Jason. Your solution works.
Previous Topic:report parameters ALL_DATES or (START_DATE, END_DATE)
Next Topic:report viewer
Current Time: Mon Jul 21 22:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.46298 seconds
