Home » Eclipse Projects » Nebula » CTableTree limited to 2048 rows?
Re: CTableTree limited to 2048 rows? [message #14556 is a reply to message #14528] |
Wed, 18 October 2006 07:35   |
Hi Jeremy,
Here's a simple snipplet reproducing this:
CTableTree ctt =
new CTableTree(shell, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
CContainerColumn column1 = new CContainerColumn(ctt, SWT.LEFT);
column1.setText("Column 1");
column1.setWidth(200);
for (int i = 0; i < 2050; i++) {
CTableTreeItem item = new CTableTreeItem(ctt, SWT.NONE);
item.setText(new String[] { "item " + i});
I'm using nebula from eclipse cvs head.
cheers,
asgeir
Jeremy Dowdall wrote:
> I'm not able to reproduce this on Linux GTK so it may be a bug on the
> Windows implementation - can you post a snippet showing this problem?
> Asgeir Frimannsson wrote:
>> Hi all,
>> I'm trying to use a CTableTree (with the experimental viewer) to
>> display a tree from an EMF model. However, I'm unable to display more
>> than 2048 rows in the table. The remaining rows are simply greyed out,
>> as shown on this screenshot (modified snipplet to display 2050 rows):
>> http://everest.fit.qut.edu.au/~n4198522/ctabletree.png
>> Does anyone know why that is so?
>> cheers,
>> asgeir
Re: CTableTree limited to 2048 rows? [message #14585 is a reply to message #14556] |
Wed, 18 October 2006 10:08   |
Chris Gross gave this insight:
> I believe this is a result of using a ScrolledComposite. Widgets have
> size limit on Win and the way ScrolledComposite works requires that
> the inner content size to its full necessary height. So if the size
> of that inner content can only be as large as the Win limit (which I
> think is like 32k pixels but I can't remember). Fixing this problem
> will likely require significant changes to remove the use of
> ScrolledComposite and scroll differently.
Please log a bug for this with [WIN32] in the title. Thanks.
> Hi Jeremy,
> CTableTree ctt =
> cheers,
> asgeir
>>> Hi all,
>>> out, as shown on this screenshot (modified snipplet to display 2050
>>> rows):
>>> cheers,
>>> asgeir
Re: CTableTree limited to 2048 rows? [message #14615 is a reply to message #14585] |
Thu, 19 October 2006 03:49  |
Submitted bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=161518
cheers,
asgeir
>> Hi Jeremy,
>> CTableTree ctt =
>> cheers,
>> asgeir
>>>> Hi all,
>>>> more than 2048 rows in the table. The remaining rows are simply
>>>> greyed out, as shown on this screenshot (modified snipplet to
>>>> display 2050 rows):
>>>> cheers,
>>>> asgeir
Re: CTableTree limited to 2048 rows? [message #566787 is a reply to message #14498] |
Wed, 18 October 2006 04:44  |
> Hi all,
> I'm trying to use a CTableTree (with the experimental viewer) to display
> a tree from an EMF model. However, I'm unable to display more than 2048
> rows in the table. The remaining rows are simply greyed out, as shown on
> cheers,
> asgeir
Re: CTableTree limited to 2048 rows? [message #566800 is a reply to message #14528] |
Hi Jeremy,
CTableTree ctt =
cheers,
asgeir
>> Hi all,
>> cheers,
>> asgeir
Re: CTableTree limited to 2048 rows? [message #566824 is a reply to message #14556] |
> Hi Jeremy,
> CTableTree ctt =
> cheers,
> asgeir
>>> Hi all,
>>> rows):
>>> cheers,
>>> asgeir
Re: CTableTree limited to 2048 rows? [message #566845 is a reply to message #14585] |
cheers,
asgeir
>> Hi Jeremy,
>> CTableTree ctt =
>> cheers,
>> asgeir
>>>> Hi all,
>>>> display 2050 rows):
>>>> cheers,
>>>> asgeir
Current Time: Sun Aug 31 23:09:12 EDT 2025
Powered by FUDForum. Page generated in 0.03956 seconds
