Re: Extending my own extension point [message #19690 is a reply to message #15940] |
Fri, 28 January 2005 10:00  |
Originally posted by: 0kcc.qlink.queensu.ca
Thank you so much.
It worked.
Kim Horne wrote:
> You need to make sure that your the project in which you wish to provide
> an extension for your extension point is dependant upon the plugin that
> defines it. You can do this from the Dependency tab in the plugin editor.
> Kevin wrote:
>> Hello,
>> I have used the following references to learn how to create extension
>> points. Faq#85 from the online version of eclipsefaq.org
>> http://docs.codehaus.org/display/UDIG/Creating+and+Using+Ext ension+Points
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. pde.doc.user/guide/pde_schema_editor.htm
>> I created an extension point in the plugin I am developing.
>> Then I go to Run run-time workbench.
>> In the run-time workbench I create a New Plugin Project. However when I
>> go to plugin.xml -> extensions page on the wizzard I cannot find the
>> extension point I previously created.
>> Also in the run-time workbench if I go to Help->About->Plugin Details, I
>> can see that my plugin (that I declared the extension in) is loaded.
>> Is there something else I must do to see the extension point I made?
>> Any help is appreciated. Thanks,
>> Kevin
FUDForum. Page generated in 0.08413 seconds
