Home » Newcomers » Newcomers » Extending my own extension point
Extending my own extension point [message #14473] Mon, 24 January 2005 10:23 Go to next message
Originally posted by: 0kcc.qlink.queensu.ca
I have used the following references to learn how to create extension
points.
Faq#85 from the online version of eclipsefaq.org
http://docs.codehaus.org/display/UDIG/Creating+and+Using+Ext ension+Points
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. pde.doc.user/guide/pde_schema_editor.htm
I created an extension point in the plugin I am developing.
Then I go to Run run-time workbench.
In the run-time workbench I create a New Plugin Project. However when I
go to plugin.xml -> extensions page on the wizzard I cannot find the
extension point I previously created.
Also in the run-time workbench if I go to Help->About->Plugin Details, I
can see that my plugin (that I declared the extension in) is loaded.
Is there something else I must do to see the extension point I made?
Any help is appreciated. Thanks,
Kevin
Re: Extending my own extension point [message #15940 is a reply to message #14473] Tue, 25 January 2005 09:54 Go to previous messageGo to next message
Originally posted by: kim_horne.ca.ibm.com
You need to make sure that your the project in which you wish to provide
an extension for your extension point is dependant upon the plugin that
defines it. You can do this from the Dependency tab in the plugin editor.
Kevin wrote:
> Hello,
> points. Faq#85 from the online version of eclipsefaq.org
> Kevin
Re: Extending my own extension point [message #19690 is a reply to message #15940] Fri, 28 January 2005 10:00 Go to previous message
Thank you so much.
It worked.
> Kevin wrote:
>> Hello,
>> Kevin
Previous Topic:Eclipse based ( RCP ) product not picking up the plugins
Next Topic:Building Eclipse WST
Current Time: Sat Jul 19 04:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.07599 seconds
