Home » Archived » BIRT » how to set a database schema ?
how to set a database schema ? [message #154255] Wed, 19 April 2006 04:45 Go to next message
Originally posted by: baylot.ofac.ch
I'm working on a DB2 Server.
I need to set my database schema before run my reports.
But I don't know how to run a sql command like 'set current schema PROD'
with Birt.
I need to do that because I have to run birt on differents databases which
have not the same schema.
Lionel
Re: how to set a database schema ? [message #155096 is a reply to message #154255] Fri, 21 April 2006 04:01 Go to previous messageGo to next message
Originally posted by: esteban27.free.fr
have you tried this command on the 'beforeOpen' DataSource's script ?
queryText="set current schema PROD";
Bye,
Steph
Re: how to set a database schema ? [message #155184 is a reply to message #155096] Fri, 21 April 2006 07:27 Go to previous message
I have tried this method and it has no effects :o(
I haven't got any errors but this code has no effects
Thanks for your help :o)
Lionel
Previous Topic:BIRT RPC
Next Topic:Showing only a part of a line series?
Current Time: Fri Jul 18 03:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.06086 seconds
