can't use cppunit [message #154238] |
Thu, 15 September 2005 09:47  |
Originally posted by: seb_gauthier.videotron.ca
I installed CDT 3.0.0 and had no problem running it unitl I tried to run
an executable using Run->CppUnit. When I click On "New" nothing happens
and I got this entry in the .log file:
!ENTRY org.eclipse.ui 4 4 2005-09-15 08:43:26.830
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-09-15 08:43:26.833
!MESSAGE org.eclipse.cdt.launch.ui.CDebuggerTab: method <init>()V not found
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.cdt.launch.ui.CDebuggerTab:
org.eclipse.cdt.internal.cppunit.runner.CppUnitLaunchConfigu rationTabGroup.createTabs(CppUnitLaunchConfigurationTabGroup .java:30)
org.eclipse.debug.internal.ui.launchConfigurations.CreateLau nchConfigurationAction.performAction(CreateLaunchConfigurati onAction.java:67)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction$1.run(AbstractLaunchConfigurationAc tion.java:103)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction.run(AbstractLaunchConfigurationActi on.java:106)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$ButtonActionNew.run(LaunchConfigurationsDi alog.java:1461)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$1.widgetSelected(LaunchConfigurationsDialo g.java:1430)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:439)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:35 6)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:360)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:302)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Any idea why ? I'm running eclipse 3.1 on Fedora Core 3
FUDForum. Page generated in 0.23927 seconds
