Home » Eclipse Projects » GEF » How to follow RedBook GEF example
How to follow RedBook GEF example [message #154225] Fri, 15 October 2004 00:28 Go to next message
Originally posted by: philipsseow.yahoo.com.sg
I've downloaded the RedBook GEF example (SG246302) & try to follow the
steps to create my first GEF editor. However, I found that the Jave
Editor reported that "org.eclipse.gef" can't not be resolved.
I've checked that all GEF plug-in & features has been installed. So,
what steps did I miss & how to fix it ?
BTW, my Eclipse version is 3.0.1.
Re: How to follow RedBook GEF example [message #154275 is a reply to message #154225] Fri, 15 October 2004 11:40 Go to previous messageGo to next message
It sounds like you are not using the PDE to setup your plug-in project and
set the classpaths for you automatically.
"Philip" <philipsseow@yahoo.com.sg> wrote in message
news:cknjla$kko$1@eclipse.org...
Re: How to follow RedBook GEF example [message #154699 is a reply to message #154275] Thu, 21 October 2004 06:37 Go to previous messageGo to next message
Thanks for your suggestion. In fact, I'm using PDE to setup the plug-in
project. However, I found that I haven't enter org.eclipse.gef &
org.eclipse.ui.views in "Required Plug-ins" of "Dependencies" page :-)
Thanks you anyway.
> > Hi,
Re: How to follow RedBook GEF example [message #154749 is a reply to message #154699] Thu, 21 October 2004 13:45 Go to previous messageGo to next message
You are still doing it wrong. You need to import GEF using the PDE, not
create a project using the PDE, then import the source. The plug.xml file
should get imported automatically, which includes this dependency in it
already.
news:cl83i2$27r$1@eclipse.org...
> Thanks you anyway.
and
> > > Hi,
the
So,
Re: How to follow RedBook GEF example [message #155386 is a reply to message #154749] Sun, 24 October 2004 21:56 Go to previous messageGo to next message
Perhaps there is some misunderstanding. What I wanted to do is to create
my first GEF project "from scratch". So, there is no source for me to
import.
> already.
> > Thanks you anyway.
> and
> > > > Hi,
> the
> So,
Re: How to follow RedBook GEF example [message #155438 is a reply to message #155386] Mon, 25 October 2004 00:09 Go to previous message
You just use the PDE wizard, and then edit the plugin.xml file to include
org.eclipse.gef as a dependency for your new plugin.
news:clhmgt$de$1@eclipse.org...
> import.
Previous Topic:palette customization
Next Topic:Mapping from key-codes to Commands?
Current Time: Fri Jul 18 05:54:38 EDT 2025
Powered by FUDForum. Page generated in 0.05213 seconds
