Anyone has a full list of short-cut using in Eclipse? [message #154213] |
Fri, 07 November 2003 13:59  |
Originally posted by: manchi.singnet.com.sg
hi
I am looking a complete list of short-cuts available in Eclipse.
e.g. in Netbean, u can do Ctrl+L or Ctrl+K to complete your word that
has been used before (for example, to auto complete a long variable name).
any advice?
Regard,
manchi
Re: Anyone has a full list of short-cut using in Eclipse? [message #154382 is a reply to message #154264] |
Sat, 08 November 2003 00:12  |
my Ctrl-space is not working.
I believe some other program is also using this ctrl-space key.
may I is there a way to change from Ctrl-space for code assist to
something else like "Ctrl-?" ?
manchi
Eric Rizzo wrote:
> Louis Leung wrote:
>> hi
>> name).
>> any advice?
> Ctrl-Space is what you want. The feature is called "Code Assist" and can
> be configured at Window > Preferences > Java > Editor > Code Assist (tab)
> Also, there is a plug-in that shows a View with all defined Key
> bindings. Google for "eclipse key bindings plugin" to find it, or look
> at http://eclipse-plugins.2y.net
> HTH,
> Eric
FUDForum. Page generated in 0.03761 seconds
