Home » Eclipse Projects » Eclipse Platform » Anyone has a full list of short-cut using in Eclipse?
Anyone has a full list of short-cut using in Eclipse? [message #154213] Fri, 07 November 2003 13:59 Go to next message
Originally posted by: manchi.singnet.com.sg
hi
I am looking a complete list of short-cuts available in Eclipse.
e.g. in Netbean, u can do Ctrl+L or Ctrl+K to complete your word that
has been used before (for example, to auto complete a long variable name).
any advice?
Regard,
manchi
Re: Anyone has a full list of short-cut using in Eclipse? [message #154233 is a reply to message #154213] Fri, 07 November 2003 14:17 Go to previous messageGo to next message
thanks!
I have found out that someone actually posted this page for shortcut
some time back.
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/accessibility/keys.html
however, I could not find any key to auto complete my variable name.
how do I add in a new short-cut? pls help
~mc
Louis Leung wrote:
> hi
> any advice?
> Regard,
> manchi
Re: Anyone has a full list of short-cut using in Eclipse? [message #154264 is a reply to message #154213] Fri, 07 November 2003 14:59 Go to previous messageGo to next message
Originally posted by: eclipse-user.jibeinc.com
Louis Leung wrote:
> hi
> any advice?
Ctrl-Space is what you want. The feature is called "Code Assist" and can
be configured at Window > Preferences > Java > Editor > Code Assist (tab)
Also, there is a plug-in that shows a View with all defined Key
bindings. Google for "eclipse key bindings plugin" to find it, or look
at http://eclipse-plugins.2y.net
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Anyone has a full list of short-cut using in Eclipse? [message #154382 is a reply to message #154264] Sat, 08 November 2003 00:12 Go to previous message
my Ctrl-space is not working.
I believe some other program is also using this ctrl-space key.
may I is there a way to change from Ctrl-space for code assist to
something else like "Ctrl-?" ?
manchi
Eric Rizzo wrote:
> Louis Leung wrote:
>> hi
>> name).
>> any advice?
> HTH,
> Eric
Previous Topic:CPU on max when searching help
Next Topic:CVS Repository Provider
Current Time: Sat Jul 26 09:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
