Home » Modeling » GMF (Graphical Modeling Framework) » Manipulate model from two or more editors
Manipulate model from two or more editors [message #154210] Mon, 08 October 2007 18:20 Go to next message
I have an Ecore model which has say 20 classes. I generate an editor based
on GMF which touches about half of those classes. If I only want to edit
these classes then I should be all set since GMF takes care of
serialization and deserialization. However, I do need to manipulate all of
the classes (including the ones maintained by GMF editor) in another UI
form based editor. How should I do it? I was thinking connect both editors
to the serialized XML file so that I don't need to modify GMF editor. But
then I will have two memory representations of the same object, which will
cause sync problem down the load and it's vastly inefficient. Any help
appreciated.
Re: Manipulate model from two or more editors [message #154244 is a reply to message #154210] Tue, 09 October 2007 03:34 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
Shared Editing domain is one possibility. There are lots of threads here
on that subject.
Tomas
> based on GMF which touches about half of those classes. If I only want
> to edit these classes then I should be all set since GMF takes care of
> of the classes (including the ones maintained by GMF editor) in another
> UI form based editor. How should I do it? I was thinking connect both
> editors to the serialized XML file so that I don't need to modify GMF
> editor. But then I will have two memory representations of the same
> object, which will cause sync problem down the load and it's vastly
> inefficient. Any help appreciated.
Re: Manipulate model from two or more editors [message #154259 is a reply to message #154210] Tue, 09 October 2007 04:32 Go to previous messageGo to next message
If your second editor should be graphical as well you may
also look for threads with the term "DiagramPartitioning".
Nicolai
I'm using an evaluation license of nemo since 36 days.
You should really try it!
http://www.malcom-mac.com/nemo
Re: Manipulate model from two or more editors [message #154383 is a reply to message #154244] Tue, 09 October 2007 09:53 Go to previous messageGo to next message
Thanks. I do find some threads on sharing the EditingDomain. It's great
help. There are also some entries in the tips and archived Q&A in GMF
Wiki. The information is there, it's just been buried too deep. That's my
only complaint about Eclipse.
Re: Manipulate model from two or more editors [message #154776 is a reply to message #154210] Thu, 11 October 2007 03:41 Go to previous message
Hi, Feng.
It seems to me the easiest and most scaling way to do this would be to
use CDO. (one of the projects under www.eclipse.org/modeling)
Best, Philipp
Previous Topic:Initialize Diagram File Action
Next Topic:How to create two o more nodes for same model element
Current Time: Fri Jul 18 12:47:10 EDT 2025
Powered by FUDForum. Page generated in 0.06713 seconds
