Re: wizard scenario that is imposible under eclipse [message #154256 is a reply to message #154105] |
Fri, 07 November 2003 14:47  |
Originally posted by: nospam.nospam.org
WizardPage.canFlipToNextPage() worked for me
"Jane Stockdill" <janestockdill@hotmail.com> wrote in message
news:bogk83$81j$1@eclipse.org...
> Just an idea as I'm just learning about wizards myself. Could you add a
> listener to the control you are using for the selection
> then dynamically create the page and add it. Not sure how well this would
> work if the user changed there mind several times as
> I can't see a way to remove a page.
> Something along the lines of the below to the listener code ??
> MyWizard wizard = ((MyWizard)getWizard());
> wizard.page3 = new MyWizardPage();
> wizard.addPage(wizard.page3);
> Let me know if you find the answer as this would be helpful to me too.
> Thanks
> Jane
> "Alex" <nospam@nospam.org> wrote in message
news:boghh5$4t5$1@eclipse.org...
> > I am creating a wizard. the second page should be added or not based on
> the
> > selection on the first page.
> > Is this possible?
FUDForum. Page generated in 0.08984 seconds
