Home » Language IDEs » Java Development Tools (JDT) » rmi & MarshalOutputStream
rmi & MarshalOutputStream [message #154047] Tue, 13 April 2004 18:20 Go to next message
Originally posted by: sg.media-style.removeme.com
i have problems using rmi inside eclipse. (see exception below)
Since i found some other postings in the old eclipse.tools about similar
problem, but no exact solution i wish to ask again. has someone any
experimence using rmi inside of a plug-in? Any pointer for futhere
reading would be helpful as well, since i didnt found senseful
information with google.
Thanks for any hints.
Stefan
sun.rmi.server.MarshalOutputStream.annotateClass(MarshalOutp utStream.java:78)
java.io.ObjectOutputStream.writeNonProxyDesc(ObjectOutputStr eam.java:1147)
at java.io.ObjectOutputStream.writeClassDesc(ObjectOutputStream .java:1100)
java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputS tream.java:1241)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.j ava:1052)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.ja va:278)
at java.rmi.MarshalledObject.<init>(MarshalledObject.java:92)
org.jnp.interfaces.MarshalledValuePair.<init>(MarshalledValuePair.java:23)
at org.jnp.interfaces.NamingContext.rebind(NamingContext.java:4 33)
at org.jnp.interfaces.NamingContext.rebind(NamingContext.java:4 12)
at org.jboss.naming.Util.rebind(Util.java:108)
at org.jboss.naming.Util.rebind(Util.java:95)
Re: rmi & MarshalOutputStream [message #154242 is a reply to message #154047] Wed, 14 April 2004 16:06 Go to previous message
Do you have a client or a server running as a plugin ?
Genady
Stefan Groschupf wrote:
> similar problem, but no exact solution i wish to ask again. has
> someone any experimence using rmi inside of a plug-in? Any pointer for
> futhere reading would be helpful as well, since i didnt found senseful
> Stefan
> at
> at
> at
> at
> at
> at
> at
Genady Beryozkin
http://www.genady.net/
Previous Topic:Providing an outline view for a language that translates into Java
Next Topic:How to listen from a user chosen project?
Current Time: Thu Jul 17 22:03:49 EDT 2025
Powered by FUDForum. Page generated in 0.04851 seconds
