Home » Archived » DSDP - Real-Time Software Components (RTSC) » Changing library suffix
Changing library suffix [message #1195] Thu, 12 February 2009 12:42 Go to next message
How can I change the suffix for a particular target in package.bld?
Currently I use:
for (var i = 0; i < Build.targets.length; i++) {
var targ = Build.targets[i];
Pkg.addLibrary("lib/fir_ti",targ).addObjects(SRCS);
which produces a library with the default suffix - for ti.targets.C64P it
builds lib/fir_ti.a64P. For xDAIS compliance I need the library to be
named lib/fir_ti.l64P.
Re: Changing library suffix [message #1222 is a reply to message #1195] Thu, 12 February 2009 14:49 Go to previous message
> Currently I use:
> it builds lib/fir_ti.a64P. For xDAIS compliance I need the library to be
See the suffix property of xdc.bld.Library.Attrs:
http://rtsc.eclipse.org/cdoc-tip/index.html#xdc/bld/Library. html#.Attrs
When you add a new library you can pass optional attributes of this
type. For example, in your example you can do the following:
Pkg.addLibrary("lib/fir_ti",targ, {
suffix: ".l" + targ.suffix}).addObjects(SRCS);
Previous Topic:private attributes in Build.platformTable
Next Topic:ModA changing ModB's module parameters
Current Time: Sat Jul 12 20:30:05 EDT 2025
Powered by FUDForum. Page generated in 0.03832 seconds
