Java programming question: Viewing .DOC files in Eclipse [message #153954] |
Wed, 24 May 2006 20:39  |
Originally posted by: simon_mcmahon.health.qld.gov.au
I notice that Eclipse can open a WFW .DOC file and display it within its
application frame.
How would I find the source code within eclipse that does this? I know it
uses the desktop's browser to display HTML. Maybe its using the JDIC?
I assume I can reuse that code from Eclipse in my own projects.
Simon.
Re: Java programming question: Viewing .DOC files in Eclipse [message #154033 is a reply to message #153954] |
Thu, 25 May 2006 16:48  |
Good point to start from Platform Documentation: OleFrame.
You could use this this scriplet as an example:
Display display = new Display();
Shell shell = new Shell(display);
shell.setSize (450, 350);
shell.setLayout(new FillLayout());
shell.setText ("Test Shell");
Menu bar = new Menu(shell, SWT.BAR);
shell.setMenuBar(bar);
OleFrame frame = new OleFrame(shell, SWT.NONE);
File file = new File("C:\\mytest.doc");
OleClientSite clientSite = new OleClientSite(frame, SWT.NONE, file);
int i = clientSite.doVerb(OLE.OLEIVERB_INPLACEACTIVATE);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
best regards
Ram
Simon McMahon wrote:
> application frame.
> it uses the desktop's browser to display HTML. Maybe its using the JDIC?
> Simon.
FUDForum. Page generated in 0.08227 seconds
