Home » Language IDEs » C / C++ IDE (CDT) » Windows: does cygwin have to be in my PATH?
Windows: does cygwin have to be in my PATH? [message #153801] Tue, 13 September 2005 09:02 Go to next message
Originally posted by: rich.richmoffitt-nospam-.org
Hello, this is my first post here. :)
I was wondering if c:/cygwin/bin has to be in my path, or if there's
another way that Eclipse can find make, gcc, etc. What effect does the
CYGPATH environment variable have on Eclipse/CDT?
Rich
Re: Windows: does cygwin have to be in my PATH? [message #153809 is a reply to message #153801] Tue, 13 September 2005 09:12 Go to previous message
Originally posted by: mblok.interecho.com
If you use cygwin, you need that path.
However because I don't want it always in the path,
I use instead following batch file to run eclipse.
% eclipse.bat
path=c:\cygwin\bin;%path%
start eclipse.exe
or in case of mingw
% eclipse.bat
path=E:\mingw\bin;E:\msys\1.0\bin\;%path%
start eclipse.exe
This has one disadvantage (in case of cygwin):
your programs will run from eclipse, but if run standalone it will need to
now
where cygwin1.dll is. In my case I just copy cygwin1.dll from cygwin/bin do
programs work directory.
Marek Blok
Uzytkownik "Richard Moffitt" <rich@richmoffitt-nospam-.org> napisal w
wiadomosci news:dg6ipo$en5$1@news.eclipse.org...
> Rich
Previous Topic:More Indexer Woes
Next Topic:Compiling one compile unit
Current Time: Tue Jul 22 13:53:44 EDT 2025
Powered by FUDForum. Page generated in 0.03688 seconds
