Home » Language IDEs » ServerTools (WTP) » WTP-0.7 upgrade to WTP-1.0 problem
WTP-0.7 upgrade to WTP-1.0 problem [message #153686] Sun, 25 December 2005 20:45 Go to next message
After I upgrade the WTP-1.0 (all-in-one-windows), some of my Dynamic Web
Project moves to the Other Project, and how can I change a normal project
to Dynamic Web Project ?
Eric
Re: WTP-0.7 upgrade to WTP-1.0 problem [message #153694 is a reply to message #153686] Mon, 26 December 2005 02:33 Go to previous messageGo to next message
As the above problem, the project works fine with wtp-0.7.
And now I can change it to the Dynamic Web Project by override the files
in .setting. But this caused all the JSP files in the WebContent/jsp
cannot not publish !!!!!! This make me crazy.
I tried to remove the project and create a new Dynamic Web Project.
- copy/paste the old files into the new folders.
The problem is that the JSP files in the WebContent/jsp never published
whatever I did !!!!! Any problem about the WTP-1.0 ??
Platform:
- eClipse-3.1.1 (WinXP)
- WTP-1.0
- Java 1.5._05 (J2SDK1.4.2)
- Tomcat 5.5.12
Eric
Re: WTP-0.7 upgrade to WTP-1.0 problem [message #154000 is a reply to message #153694] Tue, 27 December 2005 23:19 Go to previous messageGo to next message
Originally posted by: jazeltine.sbcglobal.net
eric138@gmail.com (Eric) wrote in news:94b82e25dd014df2740347eee9cbfded
$1@www.eclipse.org:
files
published
> Platform:
> - WTP-1.0
> - Tomcat 5.5.12
> Best regards,
> Eric
There appears to be a problem with the project definitions in the Tomcat
configuration, it does not always clean itself up. You need to select
the server in the server window, right click on it, and remove all the
projects from it. Once you do that, stop the server, and try again to
run your jsp. It should prompt you to enter a new configuration item for
Tomcat. If that does not work, you mat need to delete the server
definition entirely and start over with a new one.
Jim
Re: WTP-0.7 upgrade to WTP-1.0 problem [message #155105 is a reply to message #154000] Thu, 05 January 2006 19:19 Go to previous messageGo to next message
I have a similar problem in that EVERYTHING from under content directory
gets published to the server EXCEPT for /index.jsp. I tried removing the
server and recreating it again to no avail. Any ideas?
Fyodor Golos
Re: WTP-0.7 upgrade to WTP-1.0 problem [message #155123 is a reply to message #153686] Thu, 05 January 2006 21:20 Go to previous message
Originally posted by: subpaul.gmail.com
I had the same issue when using a Basic J2EE Runtime with resin.
Previously I had resin working flawlessly with WTP 0.7.
Now no jsp files are being published, and it doesn't recognize my 0.7 dynamic web applications either.
It also does not seem to like my Basic J2EE Runtime that I setup with resin. Project does not seem to remember it between eclipse restarts.
Paul
Previous Topic:changes in wtp between 0.7 and 1.0
Next Topic:Resin 2.1.4
Current Time: Wed Sep 17 07:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.03829 seconds
