Home » Eclipse Projects » GEF » How to move an EditPart
How to move an EditPart [message #153667] Mon, 11 October 2004 14:48 Go to next message
I'm having trouble implementing Move via the Selection Tool.
To install policies on the EditParts I use this:
protected void createEditPolicies()
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE,
new ResizableSelection());
The ResizableSelection is very simple:
public class ResizableSelection extends ResizableEditPolicy
protected Command getResizeCommand(ChangeBoundsRequest p_req)
return new ResizeCommand((ComponentPart)p_req.getEditParts().get(0),
p_req);
protected Command getMoveCommand(ChangeBoundsRequest p_req)
return new MoveCommand(p_req);
getResizeCommand() is called when I drag a resize handle and the
ResizeCommand() works fine.
However when I move the EditPart, getMoveCommand() is never called.
Visually the part does show the XOR graphics as it's Moved, but when the
mouse button is released nothing happens since my getMoveCommand() never
gets called.
Also as the component is being dragged, the cursor is the universal "no
way" symbol (or whatever a circle with a diagonal line through it is
called.)
Resize was so easy, but I'm stumped about how to move the EditPart. Any
guidance would be greatly appreciated.
Re: How to move an EditPart [message #153738 is a reply to message #153667] Tue, 12 October 2004 08:10 Go to previous messageGo to next message
Originally posted by: usenet.jevopi.de
I'm using the XYLayoutPolicy for this purpose. That means not the
edited element (EditPart with installed Policies) is responsible for
creating the command but its parent element, usually a XYLaout. I'm
using the XYLayoutPolicy. That's working fine. All examples I've found
are working like that, too.
I tried the selection policy first. I'm a little bit confused: Is it
possible to implement moving and sizing by using XYLayoutPolicy and
ResizablePolicy?
Jens
Re: How to move an EditPart [message #153776 is a reply to message #153738] Tue, 12 October 2004 11:30 Go to previous message
> ResizablePolicy?
> Jens
I had tried using an XYLayoutPolicy on the parent as well as Resizable and
NonResizable Policies on the children. That never worked.
Turns out that what I needed to do to get it to work was:
Do NOT install the Resizable/NonResiable policies via
EditPart.createEditPolicies().
Instead, override XYLayoutPolicy.createChildEditPolicy() to install the
appropriate resizable/nonresiable policy on the child.
This then calls the commands associated with the policy correctly.
Previous Topic:sorting an Outline view
Next Topic:GEF outside of Eclipse
Current Time: Tue Jul 22 14:45:54 EDT 2025
Powered by FUDForum. Page generated in 0.04191 seconds
