Home » Archived » BIRT » PDF viewing of charts working, tables isn't.
PDF viewing of charts working, tables isn't. [message #153552] Thu, 13 April 2006 17:39 Go to next message
Originally posted by: Malvik.yahoo.com
I'm trying to view an item as PDF. Reports with just charts are working
fine. Any reports with tables do not work (brings back an empty page).
Reports with charts and tables work, but only the charts are exported.
I've stripped out all of the formatting from my table, but still nothing.
No errors in the log.
Can anyone help me?
Re: PDF viewing of IMAGES working, TEXT isn't [message #153628 is a reply to message #153552] Fri, 14 April 2006 13:23 Go to previous messageGo to next message
> Can anyone help me?
To be more specific, the problem is that images show up in PDFs OK, but no
text is displayed.
I'm running under JBoss.
Anyone?
Re: PDF viewing of IMAGES working, TEXT isn't [message #153956 is a reply to message #153628] Mon, 17 April 2006 16:03 Go to previous messageGo to next message
Anyone? This issue is very odd and is causing me serious difficulties.
Re: PDF viewing of IMAGES working, TEXT isn't [message #154010 is a reply to message #153956] Tue, 18 April 2006 02:23 Go to previous messageGo to next message
Originally posted by: jarif.despammed.com
If you are running BIRT on unix or linux, and the BIRT version is older
than 2.0.1, you should upgrade to the latest.
Re: PDF viewing of IMAGES working, TEXT isn't [message #154152 is a reply to message #154010] Tue, 18 April 2006 10:45 Go to previous message
Thank you for the response, Jari.
So this is a known issue? I did not find a bugzilla entry for it.
What is causing the bug exactly on these platforms?
Previous Topic:visibility of an object
Next Topic:Several related xml files?
Current Time: Wed Jul 16 09:08:45 EDT 2025
Powered by FUDForum. Page generated in 1.10268 seconds
