How to draw line between two TreeView in GEF [message #153476] |
Sun, 10 October 2004 08:34  |
Originally posted by: lin_tower.hotmail.com
Hi all,
I want to draw lines between two TreeView, like the attached image
does.The lines have their own properties, so I use GEF to implement it. My
plan is to do like this:
| Tree | GEF | Tree |
but I don't know if we could connect two TreeItem. How could I implement
it?
And there is org.eclipse.gef.ui.parts.TreeViewer in GEF. I wonder what
that for,can I use that to build a tree?
Re: How to draw line between two TreeView in GEF [message #153707 is a reply to message #153602] |
Tue, 12 October 2004 01:15   |
Thanks for advice. It seems the only way is to build the TreeView in GEF,
then how to use org.eclipse.gef.ui.parts.TreeViewer to build a TreeView?
Is there any example or code snippet shows how to that?
Thanks.
lee
Randy Hudson wrote:
> I don't think you can:
> 1) Paint on top of an SWT tree reliably.
> 2) Obtain the bounding box of a TreeItem.
> You may be able to calculate the Y-location of a treeitem, and paint
> everything completely outside the tree. You will still have to track
> expand/collapse of the treeitem, and scrolling of the tree. This may not be
> possible either.
> The alternative is to render your own thing which looks like a tree, using
> GEF and Figures perhaps.
> "lee" <lin_tower@hotmail.com> wrote in message
> news:ckb9qk$dq9$1@eclipse.org...
> > Hi all,
> > | Tree | GEF | Tree |
> implement
> > it?
FUDForum. Page generated in 0.13636 seconds
