Home » Eclipse Projects » Plugin Development Environment (PDE) » Add new prespective : createInitialLayout never gets called.
Add new prespective : createInitialLayout never gets called. [message #14385] Fri, 25 July 2008 08:30 Go to next message
I have created a new perspective called TestPerspective.
When I run the application and switch to my new perspective, the switch
happens but the views I have added do not show up. Instead an empty page
appears.
Here is my extension :
<extension
         point="org.eclipse.ui.perspectives">
      <perspective
            class="my.plugin.perspectives.MyPerspective"
            icon="icons/mylogo.gif"
            id="my.plugin.perspectives.main"
            name="My Perspective">
      </perspective>
   </extension>
And here is the class
package my.plugin.perspectives;
import org.eclipse.ui.IFolderLayout;
import org.eclipse.ui.IPageLayout;
import org.eclipse.ui.IPerspectiveFactory;
public class MyPerspective implements IPerspectiveFactory {
   public void createInitialLayout(IPageLayout layout) {
      System.out.println("--------------Inside perspective-------");
      String editorArea = layout.getEditorArea();
      // place a view on the left
      IFolderLayout left = layout.createFolder("left", IPageLayout.LEFT,
(float)0.26, editorArea);
      left.addView(IPageLayout.ID_RES_NAV);
      left.addView(IPageLayout.ID_OUTLINE);
The println statement inside createInitialLayout method also doesn't show
up on the console.
Google search led me to a previous thread which suggested me to clear
metadata directory which I did with no results.
What should I be doing?
Thanks in advance.
Re: Add new prespective : createInitialLayout never gets called. [message #18948 is a reply to message #14385] Wed, 03 September 2008 08:23 Go to previous message
> appears.
> <extension
>      <perspective
>      </perspective>
>   </extension>
>   @Override
> show up on the console.
> Thanks in advance.
I have the same problem. When doing a Reset Perspective I get my views and most menu contributions.
Switching to a perspective using code doesn't do the trick either.
Re: Add new prespective : createInitialLayout never gets called. [message #578321 is a reply to message #14385] Wed, 03 September 2008 08:23 Go to previous message
> appears.
> <extension
>      <perspective
>      </perspective>
>   </extension>
>   @Override
> Thanks in advance.
Previous Topic:[P2] Problem creating repository with .product when exporting for multiple platforms
Next Topic:import existing project into workspace extension point
Current Time: Fri Jul 18 00:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.07493 seconds
