Home » Eclipse Projects » Eclipse Platform » Using external JARs in a PlugIn
Using external JARs in a PlugIn [message #153355] Thu, 06 November 2003 03:20 Go to next message
Originally posted by: mschuhma.ftisoft.at
Hi All,
How can I use external JAR's in my eclipse plug-in?
I'm able to add them to by project using the "Java Build Path / Libraries"
page. I'm then able to compile all my code - but as soon as I run my project
as "Run-Time Workbench" I cannot access the classes in the external jars (no
classdef found).
I also tried putting the jars inside my project root and added them with the
"Add JARs..." button --> same result.
Am I missing something? Can I somehow tell the "Runtime Workbench" target to
pick up my external jars?
Any help is much appreciated!
Martin.
Re: Using external JARs in a PlugIn [message #153446 is a reply to message #153355] Thu, 06 November 2003 05:14 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Martin Schuhmayer wrote:
>Hi All,
You cannot. Everything your plug-in references has either to be in a
required plug-in or inside your plug-in.
Dani
>classdef found).
>Regards,
>Martin.
Re: Using external JARs in a PlugIn [message #153708 is a reply to message #153446] Thu, 06 November 2003 13:35 Go to previous messageGo to next message
Originally posted by: frankc-ns.t310.org
>> Hi All,
> Dani
Not really true. You can add the <lib>.jar to your plugin and add a
<library name="<lib>.jar/> in your plugin.xml in the runtime section.
You also need to do add <lib>.jar to your bin.includes proporty in the
build.properties file before you generate the build.xml file for
deploying your plugin.
Frank C
Re: Using external JARs in a PlugIn [message #153796 is a reply to message #153708] Thu, 06 November 2003 15:50 Go to previous messageGo to next message
Originally posted by: meshcheryakovsemen.hotmail.com
"Frank Cornelissen" <frankc-ns@t310.org> wrote in message
news:boe484$kn7$1@eclipse.org...
> >> Hi All,
> > Dani
> Frank C
Isn't <lib>.jar inside your plugin?
-- Sam
Re: Using external JARs in a PlugIn [message #153958 is a reply to message #153708] Fri, 07 November 2003 02:42 Go to previous message
Thanks for your hints - that worked!
> >> Hi All,
> > Dani
> Frank C
Previous Topic:RFF (prelim.) in EditorToolbars to solve usability problem
Next Topic:A zany refactoring question
Current Time: Tue Jul 22 01:42:24 EDT 2025
Powered by FUDForum. Page generated in 0.28579 seconds
