Home » Archived » Test and Performance Tools Platform (TPTP) » AOP and tptp
AOP and tptp [message #14369] |
Thu, 07 April 2005 07:06  |
I want to use AOP to create log-records (using TPTP framework), and then
use log-correlation to show them in UI.
Is there any in-built support of AOP in TPTP ?
prasen
Re: AOP and tptp [message #14393 is a reply to message #14369] |
Thu, 07 April 2005 07:38   |
Hi Prasen,
Currently, we do not have any direct support for Aspect Oriented
Programming instrumentation in TPTP. However, analogous to all logging
facility support (Logging Agent and Common Base Event) TPTP provides (e.g.
Java Logging, Log4J and Commons), the logging facility is independent of
this support and the tooling (e.g. correlation). As such, when incrementing
your code with AOP instrumentation, ensure Common Base Events are logged to
an XML file, for instance. Then import the Common Base Event XML file into
the TPTP workbench. Alternatively, in your AOP instrumentation, write the
Common Base Event (XML) log records to the
org.eclipse.logging.core.LoggingAgent and attach to the named LoggingAgent
using the TPTP workbench (see the JSR_047 or Apache Commons samples).
Paul
<user@domain.invalid> wrote in message news:d334ef$qd8$1@news.eclipse.org...
> prasen
Re: AOP and tptp [message #14420 is a reply to message #14393] |
Thu, 07 April 2005 07:56   |
Thanks Paul.
Actually I am in the process of writing a log parser/correlator for
wls-log-records. The correlation logic will based on some configurable
parameters (e.g. txId,user, diagnostic-contex-id etc.) at runtime.
So, basically I was thinking of producing some perf-related log-records
to wls-log-files using wls-logging-framework-apis from my AOP advise,
and then reuse rest of the above-mentioned stuff.
As part of my wishful thinking, it would be nice to have some in-built
AOP support , so that I dont have to do the AOP-specific
jvm-configuration myself. Similar to what already exists for
TPTP-Profiler.
prasen
Paul Slauenwhite wrote:
> Hi Prasen,
> Paul
>>prasen
Re: AOP and tptp [message #14450 is a reply to message #14420] |
Thu, 07 April 2005 11:36   |
Hi Prasen,
We don't have support for real AOP, although we have Probekit which allows
you to build and run pretty complex probes that instrument staticaly Java
class files or JARs.
You may want to take a look at the Probekit documentation in TPTP 4.0 help
(under Collecting Runtime Data With User-Defined Probes).
Marius
<user@domain.invalid> wrote in message news:d337c7$ukk$1@news.eclipse.org...
> Thanks Paul.
> TPTP-Profiler.
> prasen
> > Hi Prasen,
(e.g.
incrementing
to
into
the
LoggingAgent
> > Paul
> >>prasen
Re: AOP and tptp [message #15137 is a reply to message #14450] |
Mon, 11 April 2005 19:21  |
Marius Slavescu wrote:
> Hi Prasen,
> Marius
>>Thanks Paul.
>>TPTP-Profiler.
>>prasen
>>>Hi Prasen,
> (e.g.
> incrementing
> to
> into
> the
> LoggingAgent
>>>Paul
>>>>prasen
In the future, I would be happy to see AspectJ being used in appropriate
places within TPTP -- there has been numerous occassions where I had
thought aspects would solve a problem more elegantly than the non-aspect
way.
We should investigate what it would take and if it would be practical
(and possible) to support and use AspectJ appropriately (build process,
environement, etc) in future versions of TPTP. For example, I think
aspects would be a good fit for certain parts of the test execution
engine where execution progress monitoring and logging is required.
-Scott E. Schneider
IBM Rational, Raleigh, NC
Current Time: Tue Jul 08 11:43:32 EDT 2025
Powered by FUDForum. Page generated in 0.08140 seconds
